Dell and "no audio output device installed" after Vista upgrade
S
silksoul4u
I wanted to post a solution that hopefully will help alot of folks.
I have a Dell 1501 laptop that came with Vista Home Basic. I upgraded to
Vista Home Premium and suddenly the sound wouldnt work. I would get the
message that "no audio output device was installed" even though there was one
installed, and the device manager/sound was telling me that the sound card
was working.
I have a SigmaTel High Def Audio CODEC.
Here's how I fixed it. I went to this page and downloaded this driver:
http://www.support.dell.com/support...=1&vercnt=1&formatcnt=1&libid=3&fileid=195629
I restarted my computer and now the sound works fine again!
Hope this helps.
M
sound problem
I had the same problem with the exact same components. I couldn't find anything that worked but i downloaded this driver and my sound fired right up after a restart.
Thanks a lot,
Matt
EggHeadCafe.com - .NET Developer Portal of Choice
http://www.eggheadcafe.com
D
Debra
Thank you!! I have searched everywhere for this solution. Worked perfectly!!
"silksoul4u" wrote:
> Hi,
> was working.
> Hope this helps.
S
Swami ji
YEH, the driver works but the sorround sound quality and enhancements of
the Audio Codecs are gone .
Please help me in that, as DELL has replaced 3 of my systems and now
ultimately the buck is on VISTA as per the TECH service team of ESTEEMEEED
DELL
''''Swami''''
"silksoul4u" wrote:
> Hi,
> was working.
> Hope this helps.
T
tekas
I had exactly the same problem that you had and I have been trying for
the past 3 days to solve it. I downloaded a couple of SigmatelDrivers
(that dell prescribed) and also the Creative Soundblaster Audigy that
Dell shipped.
None of them worked.
Then I looked at your post and thought this should fix it. Since mine
is exactly the same problem as your... It stopped working after I
upgraded to Vista premium.
Unfortunately it isn't still working for me.
Can anyone please help me
Regards
Saket
silksoul4u;2614861 Wrote:
> Hi,
> to
> the
> was one
> card
> was working.
> http://tinyurl.com/2p5dzh
> Hope this helps.
tekas
tekas's Profile: http://forums.techarena.in/member.php?userid=25780
View this thread: http://forums.techarena.in/showthread.php?t=694159
M
mafas
yay! it works! lol, thanks very much! I was thinkng that I wouldn't ever
be able to solve it, and then I come across this post... thank you!
> Hi,
> to
> the
> was one
> card
> was working.
> Hope this helps.
mafas
mafas's Profile: http://forums.techarena.in/members/mafas.htm
View this thread: http://forums.techarena.in/vista-hardware-devices/694159.htm
T
theron
My audio worked fine until Vista Service Pack 1. I have a Dell Inspiron
1720 with a Sigma Tel High Definition Audio CODEC driver. Apparently
Sigma Tel was bought out by another company. Dell says that Windows
should have a new driver, and Windows says that Dell should have a new
driver. I have tried numerous drivers without success.
Does anyone have a solution?
theron
theron's Profile: http://forums.techarena.in/members/theron.htm
