Desktop background keeps going black
S
Steven L.
Hi all,
I have Vista Home Premium SP1.
I have set my Desktop Background to be one of my favorite pictures.
But every half hour or so, without any warning, the Desktop Background
resets itself to black, and I have to go back into Control Panel to
reset the background to my picture.
What is wrong?
-- Steven L.
G
Gene E. Bloch
On 12/07/09, Steven L. posted:
> Hi all,
> But every half hour or so, without any warning, the Desktop Background resets
> itself to black, and I have to go back into Control Panel to reset the
> What is wrong?
Maybe you have set up a slide show and the picture is alone in its
folder...or maybe you have set up to blank your screen after a half
hour...
If not, I have no other ideas, sorry.
> -- Steven L.
Your signature delimiter should have a return after the space and
before the Steven. Correct format is two hyphens, a space, a return,
and the signature itself.
Gene Bloch 650.366.4267 lettersatblochg.com
S
Steven L.
>> Hi all,
>> What is wrong?
> folder...or maybe you have set up to blank your screen after a half hour...
I'm sorry, I didn't mean to imply that the desktop background goes blank
at regular time intervals.
I just meant that the desktop background goes black *frequently*. It
seems to happen when I'm doing something major like installing a new
application or something.
I've done some Google searches, and it seems that other users of Vista
have reported a similar problem--but so far, none of the proposed fixes
have helped.
Perhaps there's something in Service Pack 2 that will fix this. I've
still got only SP1.
Steven L.
M
Michael
Gene, I wasn't aware Vista had that option. I thought only 7 was able to do
a slideshow for backgrounds.
"Don't pick a fight with an old man.
If he is too old to fight, he'll just kill you."
"Gene E. Bloch" <letters@newsgroup> wrote in message
news:eiugQx6dKHA.5568@newsgroup
>> Hi all,
>> resets itself to black, and I have to go back into Control Panel to reset
>> What is wrong?
> hour...
>> -- Steven L.
> Your signature delimiter should have a return after the space and before
> the Steven. Correct format is two hyphens, a space, a return, and the
> signature itself.
C
Charlie Tame
There was an example program to create one in the Visual Studio set up
at one time because I played with it, but was that not an option in the
image viewer or whatever it was called?
Charlie Tame
> to do a slideshow for backgrounds.
M
Michael
I never played with Visual Studio. Thanks for the info.
"Charlie Tame" <charlie@newsgroup> wrote in message
news:eVQh9ZDeKHA.1648@newsgroup
> There was an example program to create one in the Visual Studio set up at
> one time because I played with it, but was that not an option in the image
> Charlie Tame
G
Gene E. Bloch
Yeah, I think I screwed up here. I was running Mac OS X for a while,
and apparently misremembered where the slideshow was.
I blush with shame (not really!) - but I am sorry to have misled.
On 12/08/09, Michael posted:
>>> Hi all,
>>> What is wrong?
>>> -- Steven L.
>> signature itself.
>> -- Gene Bloch 650.366.4267 lettersatblochg.com
M
Michael
#8
Now see what you've gone and made me do?!?! I went and tore apart Vista
looking for sideshow and you know what I found? Windows 3.1. :-)
news:uQ5BOvDeKHA.2188@newsgroup
> Yeah, I think I screwed up here. I was running Mac OS X for a while, and
>>>> Hi all,
>>>> What is wrong?
>>> hour...
>>>> -- Steven L.
>>> signature itself.
G
Gene E. Bloch
#9
OK, now my head is spinning. Yikes :-)
Are you trying to tell me that Vista is lipstick on a pig?
>>>>> Hi all,
>>>>> What is wrong?
>>>> hour...
>>>>> -- Steven L.
>>>> signature itself.
M
Michael
#10
As much as I like Vista and pork, compared to 7, Vista *is* the pig.
news:#eF8XdFeKHA.6000@newsgroup
>>>>>> Hi all,
>>>>>> Background resets itself to black, and I have to go back into Control
>>>>>> Panel to reset the background to my picture.
>>>>>> What is wrong?
>>>>> hour...
>>>>>> -- Steven L.
