desktop confusion...
djprov
4
Hi Knowledgeable Folks,
Last night I downloaded a program (DVD writing program) and it ask to be installed on the DESKTOP ... or so I thought :confused: .... so when the install wizard ask where to install, I changed where the automatic set location was (the programs folder) to the Desktop, doe dee doe. Now I have succesfully installed the program on the desktop but can't see the desktop for all the files. :cry:
1) How do I decide which files belong to the downloaded program?
2) What do I do with the files once they are ID'd?
3) Should I move them to the ... Programs Floder... & How do I do that?
or something totally different.
Sorry for the compound question, just looking for some direction. Thanks.
dp
LeeTutor
Vista Expert - MVP
178
Location
Coral Springs, FL
Try going into Control Panel -> Programs and Features -> find your program on the list and then uninstall it. This should remove all, or anyway most, of the files on your desktop that belong to the program. Then re-run the install without changing the default location.
M
Malke
Uninstall the program from Control Panel>Programs & Features. Reboot. Your
Desktop should now be clear of those files.
If you want the program, reinstall it and use the defaults. You
misunderstood the directions.
Malke
MS-MVP
Elephant Boy Computers - Don't Panic!
FAQ - http://www.elephantboycomputers.com/#FAQ
