Desktop file ares no longer located in C:\Users Help !!
kravit
6
Hey guys,
I booted up my computer to find that all my desktop files and bookmarks etc were gone. But All my files are still under C:\Users.
But now the desktop is refering to C:\Windows\system32\config\systemprofile\Desktop.
Can anyone help me out with fixing it so that my user files are actually under user files ?
2,456
Location
NY USA
youu install something called systempro? you have a current anti-virus? do you have a backup that you can restore from?
    Dell Inspiron E 1405
    2@2.0
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
kravit
6
All my desktop files are still in C:User, Its just that my desktop is now pointing to a new desktop and misc settings profile in C:\Windows\system32\config\systemprofile\Desktop.
So I can no longer see the files that are in C:User on my desktop and my programs no longer refer to C:User they all now work from C:\Windows\system32\config\systemprofile\Desktop.
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
kravit
6
I moved everything back to C:\Users\Mike
But now all files in User\Mike is showing up on desktop. So conctact,downloads,documents,desktop,favourites,links,music,pictures etc are all now on desktop
Pretty much everything has doubled
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
Go ahead and download and merge all of the user folders that are not correct using OPTION THREE to restore them as well.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
kravit
6
Hey Brink,
It worked, But now my C:User/Mike is called C:User/Desktop
Looks like this
Is there anyway to change it back to correct folder called Mike
Its still reading as If i have two desktops.
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
#8
Kravit,
If you type shell:UsersFilesFolder in the Start Menu search line and press enter, does it open to your C:\Users\Mike folder?
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
kravit
6
#9
Yes it does,
There is still problem with my desktop from C:users\Mike file being located to C:\Windows\System32\config\systemprofile
I did run regedit for desktop files, but hasnt linked it back to C:users\mike
I think might be because my user name is called C:Users\Desktop still. So if i could rename that back to Mike it should fix it.
It does change back to C:\Users\Mike after clicking on file location. Its just being displayed as C:\Users\Desktop as the above image.
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
#10
Not sure what happened with your main user folder, but you might create a new Adminsitrator account instead. Afterwards, copy the contents of your old account's user folders into the new account's corresponding user folders. If eveything checks out ok in the new account, then you can delete the old account from withing the new one.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
#12
Kravit,
Yep, that's what copying the contents from the old user folders to the new user folders will do. ;)
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
