desktop.ini opening on startup
J
Jerilyn
When I boot my computer in Vista, a desktop.ini file opens and displays the
following info in Notepad:
[.ShellClassInfo]
LocalizedResourceName=@%SystemRoot%\system32\shell32.dll,-21787
I can't figure out how to make it stop opening this file on startup. Any
ideas?
"Jerilyn" <Jerilyn@discussions.microsoft.com> wrote in message
news:457CD941-59B5-4C09-B7D5-FDF5CA5671AD@microsoft.com...
> the
> [.ShellClassInfo]
> ideas?
Start > All Programs > Right-click 'Startup' folder > Open > Delete
'desktop.ini' (or move it elsewhere for safe-keeping)
Jon
Check your start up programs... Start/Orb, type msconfig, startup tab
> the
> [.ShellClassInfo]
> ideas?
J
Jerilyn
I already checked that. Startup is 'empty'. Weird huh? What else could it
be?
> > the
> > [.ShellClassInfo]
> > ideas?
> Jon
serices?
news:F65104A7-1957-4FD6-960F-3AAD0E34C481@microsoft.com...
>it
> be?
>> > the
>> > [.ShellClassInfo]
>> > Any
>> > ideas?
>> Jon
C
Cal Bear '66
What is in the Startup tab of msconfig?
I Bleed Blue and Gold
GO BEARS!
> be?
>> > the
>> > [.ShellClassInfo]
>> > ideas?
>> Jon
J
Jerilyn
In the startup tab of msconfig, I have:
Windows Defender
Symantec Security Technologies
Microsoft Windows Operating System
All other options are "unchecked".
> GO BEARS!
> > be?
> >> > the
> >> > [.ShellClassInfo]
> >> > ideas?
> >> Jon
J
Jerilyn
#8
I have several things in Services. What am I looking for?
"Mac" wrote:
> serices?
> >it
> > be?
> >> > the
> >> > [.ShellClassInfo]
> >> > Any
> >> > ideas?
> >> Jon
D
DefecTalisman
#9
Try using windows defender.
Click tools in defender. Then Software explorer. Finally make sure the
selected category is startup programs. Check down the list and find the
program you want to stop. Then click it and disable.
Or you could download Startup Control Panel and use that rather.
news:47D20544-68B7-4D4C-AEE0-B7FDB2BFB9F5@microsoft.com...
> "Mac" wrote:
>> serices?
>> >could
>> >it
>> > be?
>> >> > displays
>> >> > the
>> >> > [.ShellClassInfo]
>> >> > Any
>> >> > ideas?
>> >> Jon
R
#10
> the
> [.ShellClassInfo]
> ideas?
Notepad Starts With "[.ShellClassInfo]
LocalizedResourceName=@%SystemRoot%\System32\Shell32.dll,-21787 When You
Start Your Computer
http://support.microsoft.com/kb/330132/en-us
This article applies to XP. See if substituting \Users for \Documents and
Settings in the steps provide to resolve it helps.
Rock [MS-MVP User/Shell]
>it
> be?
It may well be in there, but just not visible.
Control Panel (Classic View)> Folder Options > View (tab) > Enable the
options for viewing hidden and 'protected operating system files'
Jon
J
Jerilyn
#12
Thanks. I disabled it in Defender like you said and it worked!
> > "Mac" wrote:
> >> serices?
> >> >could
> >> >it
> >> > be?
> >> >> > displays
> >> >> > the
> >> >> > [.ShellClassInfo]
> >> >> > Any
> >> >> > ideas?
> >> >> Jon
SDCoburn
1
#13
[.ShellClassInfo]
ideas?
The same issue just started with me a few days ago. I scanned for viruses/spyware. I don't know what the problem is.
R
Ramesh, MS-MVP
#14
Desktop.ini file automatically opens when you start your Windows Vista
computer:
http://www.winhelponline.com/articl...en-you-start-your-Windows-Vista-computer.html
Regards,
Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
The Winhelponline Blog: http://www.winhelponline.com/blog
Windows® Troubleshooting: http://www.winhelponline.com
"SDCoburn" <guest@xxxxxx-email.com> wrote in message
news:a5a9750e304f5383ea331e434711d54b@xxxxxx-gateway.com...
>> the
>> [.ShellClassInfo]
>> Any
>> ideas?
> SDCoburn
