Determine 32 bit or 64 bit of an OS
C
Charlie Russel - MVP
$ENV:Processor_Architecture will yield x86 if 32-bit and AMD64 if 64-bit.
Charlie.
http://msmvps.com/blogs/russel
"Joe Morris" <j.c.morris@newsgroup> wrote in message
news:hie55a0co2@newsgroup
> "IT Staff" <jkklim@newsgroup> wrote:
>> Can powershell v2 do that ?
> I was going to answer "of course" since I expected the 'platform' property
> of the osversion object to provide that information. Checking that just
> to be sure sadly yields the answer that it doesn't:
> $os = [environment]::osversion
> $os.platform
> ...yields "Win32NT" for both 32- and 64-bit platforms, at least for
> Windows 7. Sigh...
> Although some Microsoft documentation claims that build numbers can be
> used to diffrentiate between different platform versions, that's not
> correct (Windows 7 and Server 2008 R2 both report build 7600 for both
> address space values. (Server and client are distinguished by
> HKLM\Software\Microsoft\Windows NT\CurrentVersion\SoftwareType = "System"
> or "Server".)
> There's probably a native POSH test for it somewhere, but a quick check
> (and one that's self-documenting) is to look at the environment variable
> Processor_Architecture. Its value will be "x86" for 32-bit and "AMD64"
> for 64-bit (not necessarily with an AMD chip). There's a third
> possibility ("IA64") if the Itanium flavor is being used.
> Or as a practical matter, with a fractionally lower assurance of a correct
> answer, test for the existence of the folder "C:\Program Files (X86)" as a
> test for the 64-bit platform.
> Or you could interrogate any of the several 64-bit-related Registry
> settings in HKLM\Software\Microsoft\Windows\CurrentVersion or ...\Windows
> NT\CurrentVersion. Look at these two keys on a 64-bit system and you'll
> see the entries which tell you that you're running a 64-bit version.
> Joe Morris
K
Karl Mitschke
Hello Charlie Russel - MVP,
> 64-bit.
>> property of the osversion object to provide that information.
>> Checking that just to be sure sadly yields the answer that it
>> doesn't:
>> $os.platform
>> Windows 7. Sigh...
>> be used to diffrentiate between different platform versions, that's
>> not correct (Windows 7 and Server 2008 R2 both report build 7600 for
>> both address space values. (Server and client are distinguished by
>> "System" or "Server".)
>> check (and one that's self-documenting) is to look at the environment
>> variable Processor_Architecture. Its value will be "x86" for 32-bit
>> and "AMD64" for 64-bit (not necessarily with an AMD chip). There's a
>> third possibility ("IA64") if the Itanium flavor is being used.
>> correct answer, test for the existence of the folder "C:\Program
>> Files (X86)" as a test for the 64-bit platform.
>> ...\Windows NT\CurrentVersion. Look at these two keys on a 64-bit
>> system and you'll see the entries which tell you that you're running
>> a 64-bit version.
>> Joe Morris
Charlie;
Will that work if a 32 bit OS os installed on top of an x64 processor?
Karl
http://unlockpowershell.wordpress.com/
C
Yes. It reports x86 for a 32-bit OS on 64-bit hardware.
Charlie.
"Karl Mitschke" <karlmitschke@newsgroup> wrote in message
news:d66cd4c21a4e68cc60b2178fff3d@newsgroup
>> 64-bit.
>>> doesn't:
>>> $os.platform
>>> Windows 7. Sigh...
>>> a 64-bit version.
>>> Joe Morris
> Charlie;
> Karl
T
Thomas Lee
In message <O5iQpwskKHA.1824@newsgroup>, Charlie Russel - MVP
<Charlie@newsgroup> writes
Only if you run this command from a 64-bit powershell prompt. If you run
it from a 32-bit console you get this:
PSH [C:\foo]: ls env:processor*
Name Value
PROCESSOR_ARCHITECTURE x86
PROCESSOR_ARCHITEW6432 AMD64
PROCESSOR_IDENTIFIER Intel64 Family 6 Model 23 Stepping 6,
GenuineIntel
PROCESSOR_LEVEL 6
PROCESSOR_REVISION 1706 When run from a 64-bit prompt you get:
PSH [C:\foo]: ls env:proc*
Name Value
PROCESSOR_ARCHITECTURE AMD64
PROCESSOR_LEVEL 6
GenuineIntel
Thomas Lee
doctordns@newsgroup
B
Bob Landau
Thomas,
I guess it all depends on whether you want to know whether you're in a 32
bit process or OS. IT Staff has stated OS so I guess what you've pointed out
is important.
Here is what I used to determine whether this is a 64 bit OS or not. This as
you've pointed out will work in 32/64 bit OS as well as WOW
if ($ENV:Processor_Architecture -eq 'x86' -and (test-path
env:\PROCESSOR_ARCHITEW6432))
echo 'WOW layer 64 bit OS/32 bit process'
elseif ($ENV:Processor_Architecture -eq 'x86')
echo '32 bit OS'
elseif ($ENV:Processor_Architecture -eq 'AMD64')
echo '64 bit OS'
else
echo 'Unknown'
> Name Value
> GenuineIntel
> PROCESSOR_LEVEL 6
> PROCESSOR_REVISION 1706 >
> Name Value
> PROCESSOR_LEVEL 6
> GenuineIntel
> Thomas Lee
> doctordns@newsgroup
C
32-bit console? What's that? <grin>
Charlie.
"Thomas Lee" <tfl@newsgroup> wrote in message
news:REKkVkrgp2SLFA0V@newsgroup
> Name Value
> GenuineIntel
> PROCESSOR_LEVEL 6
> Name Value
> PROCESSOR_LEVEL 6
> GenuineIntel
> Thomas Lee
> doctordns@newsgroup
J
Joe Morris
#8
Answer: one of the less-well-publicized pieces of 64-bit Windows. I hadn't
expected the difference in the reported value of PROCESSOR_ARCHITECTURE (a
tip o' the hat to Thomas for that bit of information!), so it looks like a
more reliable test than the one for PROCESSOR_ARCHITECTURE that I proposed
upthread, and which was echoed by Charlie, could be redesigned to declare
the system to be a 64-bit platform if either the environment variable
PROCESSOR_ARCHITEW6432 exists, *or* the environment variable
PROCESSOR_ARCHITECTURE has a value of "AMD64".
Perhaps a more reliable test (the above environment variables could be set
by a hacker, or a student with not enough work to keep him busy) would be to
test for the existence of the Registry data item
HKLM\Software\Microsoft\Windows\CurrentVersion [ProgramFilesDir (x86)]
which hopefully isn't writable by normal users.
Joe
