Disable drag n' drop
J
Jack B. Pollack
On VPC 7 I installed the 'enhanced screen features' so the mouse would work
more seamlessly between host & VPC.
Is there a way to disable just the drag n' drop file transfer between the
two machines (and maybe the clipboard interaction)?
R
Robert Comer
Ben has a blog post on this:
http://blogs.msdn.com/virtual_pc_gu...ipboard-integration-etc-under-virtual-pc.aspx
Bob Comer <Microsoft MVP - Virtual Machine>
"Jack B. Pollack" <[email protected]> wrote in message
news:[email protected]
> work more seamlessly between host & VPC.
J
Jack B. Pollack
Perfect. Thanks
"Robert Comer" <[email protected]> wrote in message
R
Robert Comer
You're welcome!
news:uCU#[email protected]
> Perfect. Thanks
>>> the two machines (and maybe the clipboard interaction)?
