Disable Server 2008 Recycle Bin for All Users
R
Rick Bridges
To disable the Recycle Bin for all users on Server 2008, you need to enable loopback processing in the Group Policy Object applied to the server.
Go to Computer Configuration > Policies > Administrative Templates > System > Group Policy and enable 'User Group Policy loopback processing mode'.
Next, set the Recycle Bin policy. Go to User Configuration > Policies > Administrative Templates > Windows Components > Windows Explorer and enable 'Do not move deleted files to the Recycle Bin'.
ThomVis wrote:
Re: Disable recycle bin on Windows Server 2008
27-Mar-09
On 26 mrt, 15:02, Meinolf Weber [MVP-DS] <meiweb(nospam)@gmx.de>
wrote:
Tried both 0 and 1, for old and new users the default is still 10% of
the drive space. (rebooted to make it effective).
Thanks for thinking along.
Previous Posts In This Thread:
On Friday, March 27, 2009 7:43 AM
On our Windows Server 2003 machines we disabled the recycle bin (the
=93Do not move files to the Recycle Bin. Remove files immediately when
deleted=94 option, NukeOnDelete=3D1 in the HKLM registry). You delete a
file, it is gone. So no application administrator could use up
unnecessary drive space "forgetting" to empty the recycle bin. In
Windows Server 2003 it is a system wide setting.
Now we want the same on Windows Server 2008, but MS changed it to a
per user, per volume setting. We want NukeOnDelete=3D1 as default for
all users on all volumes. Doing this on the default C and D drives
would be possibly using HKU\.Default, but I don=92t know the volume
signatures of the SAN volumes to be mounted in the future.
Anyone have any idea how to accomplish this?
Hello thomvis@newsgroup,
The policy:
User configuration, policies, administrative templates, windows components,windows
explorer, in the right pane "Maimum allowed Recycle Bin size" applies to
all volumes. So it should be your's.
Best regards
Meinolf Weber
Disclaimer: This posting is provided "AS IS" with no warranties, and confers
no rights.
** Please do NOT email, only reply to Newsgroups
** HELP us help YOU!!! http://www.blakjak.demon.co.uk/mul_crss.htm
Submitted via EggHeadCafe - Software Developer Portal of Choice
Some Useful Javascript Debugging Functions
http://www.eggheadcafe.com/tutorial...2-cefc71222c71/some-useful-javascript-de.aspx
