Disable Tablet PC
I have just obtained a new computer with Vista Ultimate. It came with the
Tablet PC. I use a Wacom tablet.
At this time I do not use handwriting and therefore find the small icon that
appears all the time quite annoying. So I wnat to know how I can disable this
until I want to use it.
Thanks
M
Mark L. Ferguson
Disable the tablet in Device Manager.
Please use the Communities guidelines when posting.
http://www.microsoft.com/wn3/locales/help/help_en-us.htm
Use the "Ratings" feature. It helps the new users.
Mark L. Ferguson MS-MVP
https://mvp.support.microsoft.com/profile/Mark.Ferguson
"Jib" <Jib@xxxxxx> wrote in message
news:274B960D-C3E2-489B-997A-AD91B6516361@xxxxxx
> that
> this
> Thanks
Thank you Mark. In Device Manager I can only find reference to my Wacom
tablet. What I want to disable is the Tablet PC. Where in Device driver can I
find it?
Thanks.
> > that
> > this
> > Thanks
S
Sinclair
Right click the small icon >in Pen and Input Devices window choose the flicks
tab >clear the check to "Display flicks icon in the notification area"
> find it?
> Thanks.
> > > that
> > > this
> > > Thanks
Thank you "Sinclair". I went to the Control panel-rt. clicked on the Pen and
Input Devices icon - chose the Flicks Tab and unchecked the "Display flicks
...." box. Then I Restarted the computer and the little box (with the pen in
it) keeps poping up. Did I do the wrong thing? If not, have you anything else
to suggest?
> > find it?
> > Thanks.
> > > > that
> > > > this
> > > > Thanks
S
Sinclair
No. You did the right thing. You now by saying …the little box….makes me
think we’re not talking about the same icon. The flicks icon I meant is a
little hand holding a pen.
I dunno what else to suggest.
> to suggest?
> > > find it?
> > > Thanks.
> > > > > that
> > > > > this
> > > > > Thanks
S
Sinclair
Dear Jib
Click the Orb and type Tablet PC Input Panel in the start search box. Once
open>click the Tools little arrow >point to Opening tab and uncheck the
box... Show the Input Panel icon the taskbar.
> > to suggest?
> > > > find it?
> > > > Thanks.
> > > > > > that
> > > > > > this
> > > > > > Thanks
S
Sinclair
#8
Correction to my previous post
Jib
open>click the Tools little arrow >click Options>point to the Opening tab
and uncheck the three boxes to the far left in the Input Panel icons and tabs
center pane.
Please confirm we made it.
"Sinclair" wrote:
> Dear Jib
> > > to suggest?
> > > > > find it?
> > > > > Thanks.
> > > > > > > that
> > > > > > > this
> > > > > > > Thanks
