disappearing [+] and [-] boxes in Explorer
I use Explorer in Classic view, with "simple folder view" disabled.
This works fine as long as the cursor is over the folder pane, but when
the folder pane loses focus, all of the {+] and [-] boxes for expanding
and collapsing the tree disappear, leaving gaps in the lines that show
the tree structure. This really looks amateurish, and it's distracting
to have the boxes appear and disappear as the cursor passes over the
folder pane. Is there any way to make the boxes permanently visible?
Am I missing some obvious option in the folder view settings?
Ray
(remove the Xs to reply)
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Ray
Hi Ray,
I find that this helps me to keep things easier to keep track of what is opened in the folder tree. You might like it as well.
http://www.vistax64.com/tutorials/81668-open-folder-icon.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
brink <brink.32eeta@xxxxxx-mx.forums.net> wrote:
>> disabled. This works fine as long as the cursor is over the
>> folder pane, but when the folder pane loses focus, all of the {+]
>> and [-] boxes for expanding and collapsing the tree disappear,
>> leaving gaps in the lines that show the tree structure. This
>> really looks amateurish, and it's distracting to have the boxes
>> appear and disappear as the cursor passes over the folder pane.
>> Is there any way to make the boxes permanently visible? Am I
> Hi Ray,
Thanks, that's a nice enhancement, even if it doesn't keep the [+]
boxes from disappearing ;) I was wondering last week why there
wasn't a different icon for open folders, and now there is.
A related question: is there an easy way to change the default folder
icon in Explorer? I searched a bit on vistax64.com and in Google but
didn't find anything. The standard one doesn't look much like a folder
to me -- more like a side-by-side refrigerator.
Ray
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
> Ray;556973 Wrote:
> Hi Ray,
Ray
Ray,
You can change them one by one by using these methods below, but they will no longer have the thumbnail preview.
http://www.vistax64.com/tutorials/88515-folder-icon-change.html
and
http://www.vistax64.com/tutorials/88519-shortcut-folder-file-icon-change.html
This 3rd party program "Vista Manager" will let you do it. It has a 15 day fully functional trial period to do it in.
Tweak and Optimize your Windows Vista - Vista Manager
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
R
brink <brink.32h8w4@xxxxxx-mx.forums.net> wrote:
>> folder icon in Explorer?
> _http://www.vistax64.com/tutorials/88515-folder-icon-change.html_
> and
> hange.html
I found that, but doing them one by one is way too much work.
> 'Tweak and Optimize your Windows Vista - Vista Manager'
> (http://yamicsoft.com/vistamanager/index.html)
Thanks, I'll give it a try.
Ray
