Disk Defrag affecting Sleep Function
B
Bruce UK
Hi All
Before I ran disk defragmentor for the first time in Vista, my pc would go
to sleep without any problem, since then, it attempts to sleep, monito
powers off, but hard drive still hums. You are then unable to 'wake' the pc
and have to force shutdown and reboot.
I found a solution to this on tech-net which was to open the command prompt
as an Administrator then use the command powercfg -h on. This works and is
great, only problem is I need to do this everytime before I try sleep the
pc.
Has anyone else had a problem with either disk clean up or disk defrag
affecting pc sleep?
Cheers
Bruce
T
Tony Pacc
"Bruce UK" <bruce.uk@btinternet.com> wrote in message
news:5030C40E-1EBE-45AB-8E2B-77575DE80CFA@microsoft.com...
> Hi All
> pc and have to force shutdown and reboot.
> prompt as an Administrator then use the command powercfg -h on. This works
> and is great, only problem is I need to do this everytime before I try
> sleep the pc.
> affecting pc sleep?
> Cheers
> Bruce
yeah I am having the same problem,when it does go in to the sleep mode I
have to turn off the computer,then next time it starts I get that warning
screen,on occasion it re boots by it self.
B
Bruce UK
Apparently it has something to do with the hybernation file being made not
accessible by the system, so the pc is unable to sleep as it cannot save any
changes. I wonder if Microsoft is aware of this and working on a fix?
With the issue you had, did it start after using disk clean-up or defrag?
"Tony Pacc" <tpacc@execpc.com> wrote in message
news:%233rFzIFdHHA.284@TK2MSFTNGP05.phx.gbl...
>> Hi All
>> go to sleep without any problem, since then, it attempts to sleep, monito
>> works and is great, only problem is I need to do this everytime before I
>> try sleep the pc.
>> affecting pc sleep?
>> Cheers
>> Bruce
R
Ramesh, MS-MVP
The hybrid sleep feature and the hibernation feature in Windows Vista may become unavailable after you use the Disk Cleanup Tool:
http://support.microsoft.com/kb/928897
Regards,
Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
Windows® Troubleshooting http://www.winhelponline.com
"Bruce UK" <bruce.uk@btinternet.com> wrote in message news:BD86EBA3-0F1A-4856-B6EF-1DE6F2FBF2B9@microsoft.com...
>> Hi All
>> try sleep the pc.
>> affecting pc sleep?
>> Cheers
>> Bruce
D
Darrin
I had the same problem and I did what you did by typing the command prompt
and my sleep function worked properly ever since.
"Bruce UK" wrote:
> Hi All
> pc.
> affecting pc sleep?
> Cheers
> Bruce
B
Bruce UK
Thanks for this, two problemsare;
I have not used disk clean-up, only defrag, and
When i enable hybernation from the command prompt, this seems to be only
valid for one sleep session, I need to re-enable it after 'wake-up' to sleep
it again or my pc hangs, any ideas on a work around for this?
Thanks
Bruce.
"Ramesh, MS-MVP" <ramesh@XOX.mvps.org> wrote in message
news:OdMwjfFdHHA.4216@TK2MSFTNGP02.phx.gbl...
Regards,
>> Hi All
>> try sleep the pc.
>> affecting pc sleep?
>> Cheers
>> Bruce
R
Ramesh, MS-MVP
Bruce,
Although I have no idea about why this problem re-occurs, I think checking the event log would be a good idea.
Regards,
"Bruce UK" <bruce.uk@btinternet.com> wrote in message news:65530600-1A54-48C8-A719-31626F0DF546@microsoft.com...
Thanks
Bruce.
Regards,
>> Hi All
>> try sleep the pc.
>> affecting pc sleep?
>> Cheers
>> Bruce
B
Bruce UK
#8
Checked the event log, and there does not seem to be any mention. Any ideas?
news:uNK1e7HdHHA.2268@TK2MSFTNGP02.phx.gbl...
Bruce,
Regards,
Thanks
Bruce.
Regards,
>> Hi All
>> try sleep the pc.
>> affecting pc sleep?
>> Cheers
>> Bruce
S
skyzyk
#9
I do not use disc clean-up exactly for that reason. It kept erasing the flash
player and I had to uninstall and reinstall the falsh player every time. I
think that the de-frag use the same os as disc clean-up. I am presently using
Live One Care and I did a full virus, clean-uo back-up scan overnight while
the computer was sleeping. This morning everything is the same with no
changes to sleep settings. Have you gone into Sytem Maintenance, Power
Options, Choose when the computer sleeps? It sounds like it's your own
settings or as in the beginning your settings keep getting erased. If it
happens everytime you defrag, well, what do you think?
"Bruce UK" wrote:
> Hi All
> pc.
> affecting pc sleep?
> Cheers
> Bruce
R
Ramesh, MS-MVP
#10
Bruce,
If the System event log provides no clues, then no other ideas. But have noted down this issue.
Regards,
"Bruce UK" <bruce.uk@btinternet.com> wrote in message news:8E196F1F-3DCC-4110-8F8B-407F67BF2DDF@microsoft.com...
Bruce,
Regards,
Thanks
Bruce.
Regards,
>> Hi All
>> try sleep the pc.
>> affecting pc sleep?
>> Cheers
>> Bruce
