disk defragmenter not working?
ryancr500
5
I am new to this forum, but need some advice on the disk defragmenter.
I tried to defragment the disk last night and left it on all night.
In the morning, the disk defragmenter 'still' says... this may take a few minutes to a few hours. The disk defragmenter is ususally on a schedule which is every wednesday, but I am beginning to think it has never been defragmented.
How do I defragement the disk in this situation... and hopefully rectify the automatic scheduled defragementation.
Ryan
Brian the King
Power User
116
Disable the Windows built-in defrag schedule [Control Panel -> System and Maintenance -> Defragment your hard drive -> uncheck 'run on a schedule'] and use this;
Auslogics - Download Auslogics Disk Defrag
Much faster and natively x64. And you get a progress bar :cool:
    HP tx2000z
    AMD Turion 64 X2 TL-68 Gold Edition
    Quanta 305E/nVidia nForce 430
    4096MB DDR2 PC2-5300 @ 5-5-5-15
    nVidia GeForce Go 6150 64MB
    Realtek HD Audio/Altec Lansing
    250GB 5400RPM SATA
    8 Cell Lithium Ion Battery
    HP Echo tx2000z
ryancr500
5
I've been letting the Auslogics Disk defragmenter work on my C drive.
It appears to have stalled at about 90% of the defragementation....1/2" from the finish line! There have been no changed in the # of fragmented/defragmented files for the past 20 min.
I'll leave it for a while and see what happens.
Any ideas for what would cause the defragmentation to stall?
Ryan
Brian the King
Power User
116
Interesting that this happened with both programs, in my mind that means a file is corrupt somwhere..
Can you see which file the defragmentation has stopped on?
If not try this; Computer -> Right click "Your HDD" -> Properties -> Tools -> Error Checking -> Check both boxes, hit start, schedule a scan, and restart your computer.
Hopefully the diskcheck will find and rectify the file that is giving you trouble.
ps this will take a long time, possibly hours, and it can not be interrupted.
If you can tell which file is causing the hang-up, though, don't do the diskcheck just yet, just let us know which file it is.
    HP tx2000z
    250GB 5400RPM SATA
    HP Echo tx2000z
1,823
Run error checking first on the drive. The first defrag can take a long time depending on speed of drive, total size of files, number of files and level of fragmentation.
    16GB DDR667
    SAS RAID
