Display Adobe pdf properties in Vista
A
aorechwa
Vista does not display any properties (e.g., Title, Subject, Keywords)
of a pdf document in either the details view of Windows Explorer or in
the details pane. Is there any way to customize by editing the Registry
to cause these properties to display in Windows Explorer? Thanks for
any suggestions/assistance.
aorechwa
aorechwa's Profile: http://forums.techarena.in/members/aorechwa.htm
View this thread: http://forums.techarena.in/vista-file-management/1112089.htm
M
MartC
The same problem continues with windows 7.
Not only the properties aren´t display in details view or details pane,
but using desktop search won´t retrieve any result for pdf properties
(even though the properties are indexed). I think this was also the same
in Vista.
I´d also appreciate a lot some info on this.
Did you get any update on this aorechwa?
MartC
MartC's Profile: http://forums.techarena.in/members/martc.htm
View this thread: http://forums.techarena.in/vista-file-management/1112093.htm
