Do I need to move License/Product Keys to a new computer?
T
Teesang
Hello all.
I hope someone can help me understand restrictions (if any) I need to
consider before purchasing my new computer and moving Vista over to it.
I've searched the Internet and I can't seem to find a solid answer on this
issue.
I purchased Vista Ultimate a couple of months ago. Recently, I've decided
it's time for a new computer system. I do not purchase name brand computers.
I custom make mine. So basically I will be buying a new motherboard, case,
video card etc etc and building a new machine.
My concern is how to transfer my product key or license, or if I even need
to do so?
Can I just build the new computer and then insert my Vista Ultimate DVD and
install as normal? Or do I need to "remove" or "deactivate" the
license/product key from my old computer first? I just don't want to run
into issues when installing or activating Vista on the new machine.
Any help would be greatly appreciated.
Thanks. :)
Bare Foot Kid
R.I.P. August 13th 2014
2,616
Location
The Lowcountry
First is your copy OEM or RETAIL, It matters!
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
K
Ken Blake, MVP
On Sun, 17 Feb 2008 10:43:00 -0800, Teesang
> to do so?
There is no such thing as "deactivation," nor is there any need to do
so. The answer to your question depends on whether you bought a retail
copy of Vista or an OEM one. If it's a retail one, there is no
problem--just install and activate normally (worst case, you might be
prompted to activate by a quick and easy voice call to an 800 number).
But if you bought one of the cheaper OEM versions, you may *not* do
this at all. An OEM version comes with several disadvantages (that's
why it's cheaper), the most severe of which is that its license ties
it permanently to the first computer it's installed on. It can never
legally be moved to another computer, sold, or given away.
It's for that reason that I almost always recommend against buying an
OEM version.
Ken Blake, Microsoft MVP - Windows Desktop Experience
Please Reply to the Newsgroup
koch
Power User
94
If it's retail (re: Bare Foot Kid), you will have to reactivate over the phone, explaining that you're installing it on a completely new build. If it's OEM, it's not possible to transfer it to a new build, as it's tied that particular machine.
T
Teesang
Hi Ken, thanks for that answer.
I purchased a retail version of Vista Ultimate. So my new computer will
keep pretty much nothing form my old computer except the monitors. If I
understand correctly, I should be able to install without problems, and when
activating, I may just need to call a 1-800 number. That sounds simple
enough.
> > to do so?
> OEM version.
B
Brian W
"koch" <koch.34xzc1@xxxxxx-mx.forums.net> wrote in message
news:koch.34xzc1@xxxxxx-mx.forums.net...
Generic OEM licences cannot be transferred, but the original machine can be
'upgraded' as you see fit without breaching the EULA.
K
Ken Blake, MVP
On Sun, 17 Feb 2008 12:59:02 -0800, Teesang
You're welcome. Glad to help.
Good!
> enough.
Yes, you understand correctly.
> > > to do so?
> > OEM version.
