Documents folder not recognized as "My Documents"
D
David Witus
I have a Documents folder in my username folder but somehow Vista no longer
recognizes it as such. So, whenever I re-start my PC, Vista creates a new,
empty Documents folder in the same username folder and makes that the
Documents folder for purposes of Favorite Links, etc. I must have deleted an
attribute of some sort of the pre-existing Documents folder so now the
system views it as just a plain old folder in the username folder.
I just tried merging the two folders thinking that might accomplish it, but
I get a message that says "you need permission to do that" then asks me to
retry or cancel - neither of which, or course, get me there.
So, how do I give it back whatever attribute the Documents folder needs to
make Vista recognize it as the Documents that should be treated as "My
Documents" was treated in Windows XP?
K
Keith Miller MVP
In the 'Start Search' box on the Start Menu, type:
shell:personal<Enter>
This should open the folder that Vista thinks is your user's 'Documents'
folder.
If you view the Properties for this folder, there should be a 'Location' TAB
(not to be confused with the Location label on the 'General' tab. The
textbox contains the file system path to the folder. If it's not the folder
you want, use the 'Move' button to point it to the location you want.
However, you mention the new folder containing 'Favorites' & 'Links', and
those are normally under the User Profile folder (C:\Users\UserName).
If you could run the following commands from 'Start Search', each will open
an Explorer window. If you right-click once in the 'BreadCrumbs' bar and
select 'Copy Address', you can paste those addresses into a text file and
post them back with your reply.
shell:Personal
shell:Favorites
shell:Links
Good Luck,
Keith
Microsoft MVP [Windows XP Shell/User]
"David Witus" <[email protected]> wrote in message
news:C0B1CFBF-12BC-40[email protected]
>an attribute of some sort of the pre-existing Documents folder so now the
> but I get a message that says "you need permission to do that" then asks
> me to retry or cancel - neither of which, or course, get me there.
S
Sandy J
I am having the same issues as David and I tried your suggestion but didn't
get anywhere. When I click on "Properties" for the Documents folder, nothing
opens.
> folder.
> shell:Personal
> shell:Favorites
> shell:Links
> Good Luck,
> Keith
> news:[email protected]
K
Keith Miller MVP
In an Explorer window or on the Start Menu?
Good Luck,
Keith
"Sandy J" <[email protected]> wrote in message
> nothing
> opens.
>> folder.
>> TAB
>> folder
>> open
>> shell:Personal
>> shell:Favorites
>> shell:Links
>> Good Luck,
>> Keith
>> >longer
>> >new,
>> >deleted
>> >the
>> > asks
>> > to
S
Sandy J
It is in the Explorer window that opens when I type shell:personal in the
start search box. It opens to the documents folder that windows thinks my
documents are in, but they are in the other one. This folder has a blue
icon, the one where my docments are is a yellow folder icon. I have tried
moving my documents to the blue folder, but that just creates another folder
in the document folder and buries the documents one layer deeper. I cannot
rename or remove either document folder.
> Good Luck,
> Keith
> > nothing
> > opens.
> >> folder.
> >> TAB
> >> folder
> >> open
> >> shell:Personal
> >> shell:Favorites
> >> shell:Links
> >> Good Luck,
> >> Keith
> >> >longer
> >> >new,
> >> >deleted
> >> >the
> >> > asks
> >> > to
K
Keith Miller MVP
If Favorite Links are filling the left-pane of Explorer, click the up-arrow
at the bottom where it says 'Folders' so you can see your folder tree. You
should be able to right-click the blue folder icon and view properties -- is
that not working?
Click once in the Breadcrumbs bar of each folder to view the path to each
folder.
If you want the empty folder that Vista currently thinks is Documents folder
to remain your Documents folder, just open the other folder, press <Ctrl>+A
to select everything, right-click & select 'Copy'. Open the empty folder,
right-click & select 'Paste'. Once you're sure everything has copied over,
you can delete the contents from the other folder.
If you want the folder that currently has your documents to be designated as
the Documents folder, use the 'Move' button I mentioned in the previous post
to point it at the folder that currently contains your documents, say yes
when asked about moving all files, this will give your Documents folder its
special icon & delete the now unused folder.
Good Luck,
Keith
> folder
> cannot
>> Good Luck,
>> Keith
>> >didn't
>> > nothing
>> > opens.
>> >> 'Documents'
>> >> folder.
>> >> 'Location'
>> >> TAB
>> >> folder
>> >> and
>> >> open
>> >> and
>> >> and
>> >> shell:Personal
>> >> shell:Favorites
>> >> shell:Links
>> >> Good Luck,
>> >> Keith
>> >> >longer
>> >> >new,
>> >> >deleted
>> >> >the
>> >> > it,
>> >> > asks
>> >> > needs
>> >> > to
>> >> > "My
S
Sandy J
OK, I was able to right-click and get the properties tab to open.
The Blue icon folder has a location tab that reads:
C:\Users\Sandy\Documents\New Folder\Documents. It is empty. But it is the
default Document folder.
The Yellow icon folder has no location tab but it says in the General screen
that the location is: C:\Users\Sandy. It has all my documents in it.
When I follow your instructions to move the Blue icon folder into the Yellow
icon folder I get this error message: Cannot redirect descendant into
parent. The specified path is invalid.
How did I screw things up so badly? Is there a magical way to just delete
the empty folder? If I could, then wouldn't the default automatically go to
the folder named Documents? I can't delete either folder so the name must
have some signficance.
Thanks for your help.
> that not working?
> folder.
> Good Luck,
> Keith
> > folder
> > cannot
> >> Good Luck,
> >> Keith
> >> >didn't
> >> > nothing
> >> > opens.
> >> >> 'Documents'
> >> >> folder.
> >> >> 'Location'
> >> >> TAB
> >> >> folder
> >> >> and
> >> >> open
> >> >> and
> >> >> and
> >> >> shell:Personal
> >> >> shell:Favorites
> >> >> shell:Links
> >> >> Good Luck,
> >> >> Keith
> >> >> >longer
> >> >> >new,
> >> >> >deleted
> >> >> >the
> >> >> > it,
> >> >> > asks
> >> >> > needs
> >> >> > to
> >> >> > "My
K
Keith Miller MVP
#8
Attached is a zip file which contains a .reg file that will reset your
Documents folder. Save the zip file to your Desktop, then right-click it &
select 'Extract All...'. If you accept the defaults from expansion, you'll
now have a folder on your Desktop containing a single file,
'DefaultDocumentsEntry.reg'. Double-click this file to merge it, you'll get
a warning, but proceed through it. Log off & log back on and your Documents
folder should be reset to 'C:\Users\Sandy\Documents'.
Good Luck,
Keith
> the
> screen
> Yellow
> to
>> up-arrow
>> You
>> is
>> that not working?
>> folder.
>> folder
>> <Ctrl>+A
>> folder,
>> over,
>> as
>> post
>> its
>> Good Luck,
>> Keith
>> > the
>> > my
>> > blue
>> > tried
>> > folder
>> > cannot
>> >> Good Luck,
>> >> Keith
>> >> >didn't
>> >> > folder,
>> >> > nothing
>> >> > opens.
>> >> >> 'Documents'
>> >> >> folder.
>> >> >> 'Location'
>> >> >> TAB
>> >> >> The
>> >> >> the
>> >> >> folder
>> >> >> want.
>> >> >> 'Links',
>> >> >> and
>> >> >> will
>> >> >> open
>> >> >> bar
>> >> >> and
>> >> >> file
>> >> >> and
>> >> >> shell:Personal
>> >> >> shell:Favorites
>> >> >> shell:Links
>> >> >> Good Luck,
>> >> >> Keith
>> >> >> >no
>> >> >> >longer
>> >> >> >creates a
>> >> >> >new,
>> >> >> >the
>> >> >> >deleted
>> >> >> >now
>> >> >> >the
>> >> >> > accomplish
>> >> >> > it,
>> >> >> > then
>> >> >> > asks
>> >> >> > there.
>> >> >> > needs
>> >> >> > to
>> >> >> > as
>> >> >> > "My
K
Keith Miller MVP
#9
I suppose the actual attachment would help!!! :-)
Good Luck,
Keith
> the
> screen
> Yellow
> to
>> up-arrow
>> You
>> is
>> that not working?
>> folder.
>> folder
>> <Ctrl>+A
>> folder,
>> over,
>> as
>> post
>> its
>> Good Luck,
>> Keith
>> > the
>> > my
>> > blue
>> > tried
>> > folder
>> > cannot
>> >> Good Luck,
>> >> Keith
>> >> >didn't
>> >> > folder,
>> >> > nothing
>> >> > opens.
>> >> >> 'Documents'
>> >> >> folder.
>> >> >> 'Location'
>> >> >> TAB
>> >> >> The
>> >> >> the
>> >> >> folder
>> >> >> want.
>> >> >> 'Links',
>> >> >> and
>> >> >> will
>> >> >> open
>> >> >> bar
>> >> >> and
>> >> >> file
>> >> >> and
>> >> >> shell:Personal
>> >> >> shell:Favorites
>> >> >> shell:Links
>> >> >> Good Luck,
>> >> >> Keith
>> >> >> >no
>> >> >> >longer
>> >> >> >creates a
>> >> >> >new,
>> >> >> >the
>> >> >> >deleted
>> >> >> >now
>> >> >> >the
>> >> >> > accomplish
>> >> >> > it,
>> >> >> > then
>> >> >> > asks
>> >> >> > there.
>> >> >> > needs
>> >> >> > to
>> >> >> > as
>> >> >> > "My
S
Sandy J
#10
Thanks for all your help, Keith, it is very much appreciated. I hate to be
such a dummy, but I can't find the attached zip file to extract onto my
desktop.
> Good Luck,
> Keith
> > the
> > screen
> > Yellow
> > to
> >> up-arrow
> >> You
> >> is
> >> that not working?
> >> folder.
> >> folder
> >> <Ctrl>+A
> >> folder,
> >> over,
> >> as
> >> post
> >> its
> >> Good Luck,
> >> Keith
> >> > the
> >> > my
> >> > blue
> >> > tried
> >> > folder
> >> > cannot
> >> >> Good Luck,
> >> >> Keith
> >> >> >didn't
> >> >> > folder,
> >> >> > nothing
> >> >> > opens.
> >> >> >> 'Documents'
> >> >> >> folder.
> >> >> >> 'Location'
> >> >> >> TAB
> >> >> >> The
> >> >> >> the
> >> >> >> folder
> >> >> >> want.
> >> >> >> 'Links',
> >> >> >> and
> >> >> >> will
> >> >> >> open
> >> >> >> bar
> >> >> >> and
> >> >> >> file
> >> >> >> and
> >> >> >> shell:Personal
> >> >> >> shell:Favorites
> >> >> >> shell:Links
> >> >> >> Good Luck,
> >> >> >> Keith
> >> >> >> >no
> >> >> >> >longer
> >> >> >> >creates a
> >> >> >> >new,
> >> >> >> >the
> >> >> >> >deleted
> >> >> >> >now
> >> >> >> >the
> >> >> >> > accomplish
> >> >> >> > it,
> >> >> >> > then
> >> >> >> > asks
> >> >> >> > there.
> >> >> >> > needs
> >> >> >> > to
> >> >> >> > as
> >> >> >> > "My
K
Keith Miller MVP
#11
Sorry, I didn't see you were using the MS web interface to these groups --
attachments don't show up there -- but they do on Google:
http://groups.google.com/group/micr...a.file_management/msg/80224f70f2316601?hl=en&
At the bottom of the page, you'll see a download link.
Good Luck,
Keith
news:220F71C9[email protected]
> be
> desktop.
>> Good Luck,
>> Keith
>> > the
>> > screen
>> > Yellow
>> > delete
>> > go
>> > to
>> > must
>> >> up-arrow
>> >> You
>> >> properties --
>> >> is
>> >> that not working?
>> >> each
>> >> folder.
>> >> folder
>> >> <Ctrl>+A
>> >> folder,
>> >> over,
>> >> designated
>> >> as
>> >> previous
>> >> post
>> >> yes
>> >> folder
>> >> its
>> >> Good Luck,
>> >> Keith
>> >> > in
>> >> > the
>> >> > thinks
>> >> > my
>> >> > blue
>> >> > tried
>> >> > another
>> >> > folder
>> >> > cannot
>> >> >> Good Luck,
>> >> >> Keith
>> >> >> >but
>> >> >> >didn't
>> >> >> > folder,
>> >> >> > nothing
>> >> >> > opens.
>> >> >> >> 'Documents'
>> >> >> >> folder.
>> >> >> >> 'Location'
>> >> >> >> TAB
>> >> >> >> tab.
>> >> >> >> The
>> >> >> >> not
>> >> >> >> the
>> >> >> >> folder
>> >> >> >> want.
>> >> >> >> 'Links',
>> >> >> >> and
>> >> >> >> each
>> >> >> >> will
>> >> >> >> open
>> >> >> >> 'BreadCrumbs'
>> >> >> >> bar
>> >> >> >> and
>> >> >> >> file
>> >> >> >> and
>> >> >> >> shell:Personal
>> >> >> >> shell:Favorites
>> >> >> >> shell:Links
>> >> >> >> Good Luck,
>> >> >> >> Keith
>> >> >> >> >Vista
>> >> >> >> >no
>> >> >> >> >longer
>> >> >> >> >creates a
>> >> >> >> >new,
>> >> >> >> >that
>> >> >> >> >the
>> >> >> >> >have
>> >> >> >> >deleted
>> >> >> >> >so
>> >> >> >> >now
>> >> >> >> >the
>> >> >> >> >folder.
>> >> >> >> > accomplish
>> >> >> >> > it,
>> >> >> >> > then
>> >> >> >> > asks
>> >> >> >> > there.
>> >> >> >> > folder
>> >> >> >> > needs
>> >> >> >> > to
>> >> >> >> > treated
>> >> >> >> > as
>> >> >> >> > "My
