Solved doesn't recognize discs
mastiff1
i recently installed roxio creator pro and was having trouble burning cds so i uninstalled still didnt work and i reinstalled and uninstalled again now it doesnt reckognize any discs cd or dvd it just kicks them out and says please put in disc. everything was working fine til i tried the roxio did i lose the drivers or what and the unit is fine.
Welcome to the Forums! Keep in mind that text is a lot easier to read and understand when it is capitalized, spelled, and punctuated correctly.
Go into Device Manager and uninstall all drivers for your drive. Then reboot, and let Windows automatically reinstall them.
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (PS/2)
    Microsoft Wired Desktop 500 (USB)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's:
    Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
its burning and playing dvd's fine if i uninstall drivers what will it do to that. because i dont want to lose that also it still not playing audio cd's
Go ahead and uninstall them. You should have no problems.
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
    Other OS's:
What did you do?
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
    Other OS's:
went to windows and ran a driver search and found the problem was in my realttek high audio drivers missing. not sure which ones but found them here and it works fine now. Realtek
should have posted this sorry. thanks Mastiff1
