dos command change directory cd .
V
viensdansmavie
what is this command cd .
it is not give a error message and it doesn't anything.
what is this cd and one point cd .
G
Guest
cd . means change to the current directory.
"viensdansmavie" <viensdansmavie@newsgroup> wrote in message
news:74511025-3ECA-4B7A-A63D-F632D9789C3E@newsgroup
V
vista bill
On Sep 27, 5:52 pm, viensdansmavie
Ah, those were the days! In dos, "cd" meant change directory. Wish I
could use some of the dos commands in Vista.
Bill
K
Kerry Brown
The period is shorthand for the current directory. Normally in Windows it
isn't used. In *nix it's used a lot.
Kerry Brown
MS-MVP - Windows Desktop Experience: Systems Administration
http://www.vistahelp.ca/phpBB2/
P
PencilState
"vista bill" <billsrrempire@newsgroup> wrote in message
news:7d7caec1-987e-42d0-b827-3a805ffed288@newsgroup
Try opening a command prompt.
T
Tim Slattery
ray <ray@newsgroup> wrote:
>> it is not give a error message and it doesn't anything. what is this cd
>> and one point cd .
>'cd' is 'change directory'.
>'cd' changes to home directory.
That's Unix (and presumably Linux) behavior. Those systems have the
concept of a home directory for each user. Windows doesn't have that
concept, and AFAIK, using CD without any destination does nothing.
Tim Slattery
MS MVP(Shell/User)
Slattery_T@newsgroup
http://members.cox.net/slatteryt
G
Gordon
"Tim Slattery" <Slattery_T@newsgroup> wrote in message
news:3re1c5d5tpt00eq5398tds87avafs7kijt@newsgroup
CD and CD. do nothing on Linux, either.
Actually, using CD on *nix generally generates a 'command not found'
error.
G
Gordon
#9
"ray" <ray@newsgroup> wrote in message
news:7ic2t4F2t9b43U116@newsgroup
> error.
Well, to be pedantic, yes it does!
I
Ian D
#10
>>> and one point cd .
> Tim Slattery
> MS MVP(Shell/User)
CD\ takes you back to the root directory.
T
Tim Slattery
#11
>>>> and one point cd .
>> Tim Slattery
>> MS MVP(Shell/User)
Sure, because \ is the name of the root directory.
Tim Slattery
MS MVP(Shell/User)
G
Gene E. Bloch
#13
On 9/27/09, ray posted:
>> and one point cd .
cd without arguments prints the current directory path.
> 'cd .' changes to the current directory - i.e. where you alread are - not
> very useful.
> 'cd ..' changes to the parent directory - i.e. one level up.
Gene Bloch 650.366.4267 lettersatblochg.com
G
Gene E. Bloch
#15
On 9/29/09, +Bob+ posted:
> On Mon, 28 Sep 2009 20:57:31 -0700, Gene E. Bloch
> You can't post in here without starting an argument
I beg to differ...
If you're serious: I tried cd without arguments in a command window
before I posted, rather than take a chance on my memory (or the
possibility of a change since I last did it, three or four versions
ago).
14
#16
wat an foolish questioning make me laugh
  • Motherboard
    asrock presscott
G
Gene E. Bloch
#17
On 9/30/09, Gene E. Bloch posted:
> I beg to differ...
> If you're serious: I tried cd without arguments in a command window before I
> posted, rather than take a chance on my memory (or the possibility of a
> change since I last did it, three or four versions ago).
I just reread your post. My slowness at getting your pun embarrasses
me.
I shall recover, though. Maybe :-)
