DOS Printing: System Error 66
J
Jimbo
I just replaced a WinXP laptop with a WinVista laptop. I was able to
print from DOS programs to a network printer on the XP machine via
'redirecting' LPT1 via the command
NET USE LPT1 \\servername\printername password /user:username
Using the same script on the new Vista laptop, however, gives me the
System error 66 has occurred
The network resource type is not correct
response. This occurs regardless of whether I precede the correct
command with a precautionary 'delete'
NET USE LPT1 /delete
Any thoughts? Web based research turned up several dead ends.
Thanks,
Jim
P
PaulB
Are you opening the command prompt with "Run as administrator"?
Paul
> Thanks,
> Jim
J
Jimbo
On Wed, 18 Jul 2007 18:48:00 -0700, PaulB
Thanks for the response, Paul. I don't know the answer to that
question--I just checked, and my "Command Prompt" shortcut has all
options in the relevant tab ("Compatibility") greyed out.
FWIW, I am logged in as an administrator, and all of the other NET USE
commands succeed. (The "NET USE LPT1" command is part of a start-up
type batch file that I run manually when needed.)
Jim
P
PaulB
Right click on the CMD shortcut and click on "Run as administrator" When the
Command Prompt opens the heading will be Administrator Command Prompt.
Paul
> Jim
J
Jimbo
Thanks Paul. Doing this still gives me the error #66. Given that I'm
signed on as Administrator anyway, should I have expected different
results?
Jim
On Thu, 19 Jul 2007 13:40:02 -0700, PaulB
P
PaulB
I went back and reassigned LPT1 on my system and the only time I get that
error is when the servername\printername is wrong. I'm not sure what the
problem is.
Paul
> results?
> Jim
J
Jimbo
On Mon, 23 Jul 2007 10:46:03 -0700, PaulB
>problem is.
Thanks PaulB. Here is the specific syntax, and as mentioned, it works
fine on my XP clients but does not work on my Vista clients. I've
tried adding colons, etc., to "LPT1", but I always get error 66. Is
it possible that the syntax has changed from XP to Vista? The 'net
use' help appears to be very similar between the two OSes.
Net Use LPT1 \\server2007\hp50000 password /USER:Administrator
Jim
P
PaulB
#8
Hi Jim,
The only part of the syntax that I'm not sure of is the password. I don't
use that.
You probalby know this but type net use /? and check it out. I wish I
could be of more help.
Paul
> >problem is.
> Jim
J
Jimbo
#9
Thanks Paul; it's not the first Vista bug I've encountered :-)
On Tue, 24 Jul 2007 15:24:03 -0700, PaulB
>Hi Jim,
>use that.
fishman2
2
#10
Has anyone EVER solved this problem? It is many months and a Vista Service Pack later and this still seems to fail for me. This is a REAL pain for me Thanks for any pointers.
Harvey
C
Chuck
#11
So far the information you gave is not sufficient to even define your exact
problem, let alone try to find a solution. System Error 66 has several
possible causes, many related to network printing.
Since you did not give the conditions that exist when the error occurred,
all I can suggest is that you do is search the MSKB using Vista and system
error 66. At least half a dozen references were visible when I recently did
so. I should also mention that the search engine or the web site seemed to
be acting up a bit.
What printer make & model?
Which Vista version?
What are you doing when the error occurs?
Is there any reason why you are using "DOS" ? (Obsolete Application, etc)
"fishman@xxxxxx" <guest@xxxxxx-email.com> wrote in message
news:30961bfb18d2e081d36856048db739dd@xxxxxx-gateway.com...
> Harvey
> fishman@xxxxxx
fishman2
2
#12
This is Vista32 Ultimate. Since I am trying to virtualize the printer so that I can access it from a program written in C some twenty years ago but still very useful, the details of the printer are not material to the problem. But for the moment it is a Hewlett-Packard LJ2430 connected via an Ethernet port. As to why DOS, I MUCH prefer working in a command line environment rather than a GUI. I have been running programs in a DOS emulator since I switched to Windows NT from OS/2. This has always functioned in previous versions of Windows (NT4, 2000, and Xp) but falls flat in Vista. The actual command line that I am trying is
net use lpt3: \\boink\lj2430
where BOINK is the actual machine name and lj2430 is the share name assigned in the printer driver setup. This for the PCL6 personality of the printer. I also have drivers installed for the PCL5 and PostScript personalities, but they are not shared.
net view \\boink
shows lj2430 as a valid asset.
Now is that enough information about what I am trying to do and why? It is extremely frustrating to not be able to access the printer from these programs. Why am I getting System Error 66? And I do not seem to be alone in this; Googling gives me lots of hits on people having the problem, but seemingly none on solutions. Thanks for any help.
Harvey
be acting up a bit.
> Harvey
> fishman@xxxxxx
