Solved Driver Clean up
Drivers for hardware? If so, don't worry about this. Uninstall what you can from device Manager, and don't worry about the rest.
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (PS/2)
    Microsoft Wired Desktop 500 (USB)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's:
    Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
    Intel Core 2 Quad Q6600 (G0 Kentsfield) LGA775 (FC-LGA6)
    GIGABYTE GA-EP35C-DS3R (Rev. 2.1)
    Corsair TW3X4G1333C9A 4GB PC-10600 (2x XMS3 2GB)
    ASUS nVIDIA GeForce 8800 GT (G92GT/D8P)
    Creative SoundBlaster Audigy 2 ZS/RealTek ALC885/889A/890
    ChiMei CMV CT-730D 17inch (LCD Monitor)
    1280-1024 60Hertz (Ture Colour 32bit)
    Barracuda 7200.10 SATA 3.0Gb/s 160-GB Hard Drive ST3160815AS (RAID0)
    SUPER FLOWER 500watt Plug in Leads 24pin ATX BLACK MODEL
    Thermaltake Shark (VA7000SWA ATX) Full Tower
    Front 120mm fan (1400 RPM) /Rear 120mm (1400 RPM) blue LED
    Labtec Media Desktop Y-SAD65
    Cyber Snipa Stinger Laser Gameing Mouse (400-3200Dpi)
    Telstra BigPond Elite Liberty Cable 17Mbps/256kbps
Hiya...I would like to remove old drivers that have been left behind can anybody suggest the best way to go about this? Thanks
Download http://downloads.guru3d.com/Guru3D---Driver-Sweeper-(Setup)_d1655.html it removes, nVidia, ATI, Creative, Microsoft and Realtek drivers that are left over from uninstalls.
Oo thanks Crispy. The thing is I have never unistalled drivers just updated on a regular basis so will this just remove all the old drivers and keep the ones I am using at the moment? Thanks.
Once you have uninstalled the drivers run the program and it will clean up lift over files that are not deleted from the uninstall.
