driver power state failure
S
skytopdesigns
that is the message on the blue screen .
i am having a problem and i cant figure it out. how do i know what driver.
i belive that there is a hard drive problem but i havent figured out which
one. i have 2 hard drives. one seagate and one western digital
thanks
A
If I take that error message literally; Windows is telling you that the
drive's power feed failed while it was in operation.
Check the cables to your drives for faults, and make sure that your PSU
can provide enough power to your entire system.
Power hungry graphics cards may require bigger PSU's.
=?Utf-8?B?c2t5dG9wZGVzaWducw==?=
<skytopdesigns@xxxxxx> wrote in
news:616D9A4F-D062-4865-94AD-EB8CD2AB98C6@xxxxxx:
> driver.
> which
> thanks
*Reply to newsgroup please.
*Your mileage may vary.
*Spelling/Grammar errors free of charge.
S
skytopdesigns
hmm, havent thought of that. i have been having loads of problems. they are
posted in the vista general discussion.
my computer guy seems to think it could be a drive or the mother board ,
my computer is only 7 months old though and a powerful system. i have 2
nvidea gforce., ill tell him. he was going to wipe off the c drive and
reload vista to see if that helps ..
> > driver.
> > which
> > thanks
U
usasma
Here's a link to the error message on your Blue Screen:
http://aumha.org/a/stop.php#0x9f
You can locate the dump files on your system (usually in
C:\Windows\Minidump) in order to analyze them (
http://forums.majorgeeks.com/showthread.php?t=35246 ) and post the
information back for a detailed analysis.
But, to start, I'd update your motherboard/chipset drivers and your video
drivers - as they are (IMO) the most likely culprits.
- John
> thanks
S
skytopdesigns
you seem to be on the same thought process as my computer guy. but he found
no updates for the chipset . he too thought they were the problem
i already updated the video cards and that did stop some other problems.
> - John
> > thanks
