drop-down menu's stop working
  • Thread starter Avery Tom Deacon Harry
  • Start date
A
What's up with the drop-down menu's?
Sometimes (quite often actually) when I track up them to find a particular
file and then click on that file to open it, the file doesn't open (it
should) and the menu just disappears. I have found that the only way to
"reset" it so that the drop-down menu's work properly is to do a
shutdown/restart of the whole computer, which is damned inconvenient.
Is there a way to "reset" it without doing a shutdown/restart, or maybe to
eliminate the problem altogether?
