Dungeon Keeper 1 on Vista???? Possible???
E
esmnh
I am trying to install one of my absolute fave games on Vista Home Basic and
it installes perfectly but just wont run... I get the first screen of the
game and then it just crash. I don't get any error message or anything of
such. It just stop working... now I know its a VERY old game but is there ANY
way to make this game work???
I love this game so much, can't get sick of it... hate to think its all
over... Dungeon Keeper 2 is working fine but its not the same...
Sometimes you just find a game that captures your heart and it sticks with
you... for me those games are tetris, dungeon keeper 1 and mahajong... can
never get sick of any of them... now Keeper wont work and it breaks my heart
since Vista has been sooooooooooooooooooooo nice to me so far... havent had
much of those problems you are suppose to get with this OS...
Plz help... someone?????
M
Mark
Have you tried running in administrator mode? Right-click and select "run as
administrator"
Another idea, check the application event log and see if there is an event.
Right-click on "computer" and select "manage", then open "Event viewer",
"windows logs", "Application" and see if there is any errors that show up.
It might give a clue.
Hope that helps!
Mark
"esmnh" <[email protected]> wrote in message
news:[email protected]
> Hi,
> and
> ANY
> heart
> had
E
esmnh
Mark... thanks for trying but I have tried everything... including joing
Vista Ready Games forum and it turns out that not even the experts there
could get the game to run anymore... It seems like my computer has been
upgraded too much or something...
> administrator"
> Hope that helps!
> Mark
> > Hi,
> > and
> > ANY
> > heart
> > had
A
Andy [YaYa]
> Hi,
> and
> ANY
> heart
> had
Great game, SOOOO HARD, espically the expansion pack where each mission took
like 2-4 hours, was crazy challenging.
Wish I had troubleshooting for you, but I can't even recall if this is a dos
or windows based game.
Good luck, oh post your system specs with your problem, every time, could be
hardware related.
M
Mark
Well, if you are really desperate you can always try the Microsoft
Application Compatibility Toolkit. It has an entry for Dungeon Keeper 1 and
2, so there is a good chance you can get it running. Unfortunately it
doesn't seem to have been updated for Vista yet and the built-in fixes don't
always work, but its a try. Running the MACT is a little tough to figure out
but it allows the system to ignore (essentially to turn on and off) old
features that no longer function. I've used it with some old games and got
them running but it is kind of a hit-and-miss process. Looking at the
built-in fix, it appears that sound is a major element of what they were
solving. You might try running the game without any sound at all and see if
it will run.
You can download the MACT at:
http://www.microsoft.com/downloads/...E9-B581-47B0-B45E-492DD6DA2971&displaylang=en
Hope that helps!
Mark
E
esmnh
Believe it or not Mark but I have already tried that... I seriously doubt
there is an advice that people here on Vista can give me that they havent
given me already after I posted my first help post here... I tried that one
and so did the admins at Vista Ready Game forum and we all came up with the
same result... NADA... game wont start...
Thanks anyway but I think its time for Dungeon Keeper to die....
> it will run.
> Hope that helps!
> Mark
A
Andy [YaYa]
> one
> the
Try Overlord maybe? From the game descriptions the themes sound similar to
DK... If I can find a copy of DK tonight I'll give it a whirl Esmnh.
-A.
J
Joseph Millman
you could do what I eventually did: install Dungeon Keeper to a DOS
VirtualPC machine. It's run just fine for me so far.
R
RayMan!
On Aug 25, 7:42 pm, esmnh <[email protected]> wrote:
> Hi,
> I am trying to install one of my absolute fave games onVistaHome Basic and
> over...DungeonKeeper2is working fine but its not the same...
> you... for me those games are tetris,dungeonkeeper1 and mahajong... can
> never get sick of any of them... nowKeeperwont work and it breaks my heart
> sinceVistahas been sooooooooooooooooooooo nice to me so far... havent had
Hi there. Believe it or not, I just finished the entire game again
(for the nth time), but this time on Vista! I was having the exact
same issues as you, crashing, freezing... then I went into the Windows
DEP (Window key+pause - Advanced System Settings - Performace tab,
Settings - Data Execution Prevention tab - Add) then add the
Keeper95.exe to the list. Then go into the program file Keeper95.exe,
right click it and choose compatibility - Windows XP SP2. Now after
all this, if I run the game from the shortcut it won't work! You have
to go into the program files\bullfrog\keeper\ and run the game by
directly clicking on keeper95.exe. Weird, but worked every time!
Good luck!
Now as a payback, I would appreciate if you can tell me how you got
Keeper 2 to work on Vista! Mine will only load if it's set to W2K
compatibility but then freezes frequently, it's unplayable..
Thanks in advance!
eagleheart666
> Hi,
Good luck!
Thanks in advance!
hi there, i just tried this and i cant seem to get it working i did everything you said but it still crashes after the first screen any suggestions?
    Acer Aspire
    AMD Athlon 64 Processor
    1gb ddr
    GeForce 8600GTS 258mb
    OnBoard
    1-LG Flatron 2-Dell
    2 80 SATA Hard Drives
    Dell Optical
    worse than Dial-up
kairu10
Dont let dungeon keeper die,
i also had this problem when i upgraded to vista, but i found a soloution.
Dont know if you have tried this but, there is a program called dosbox
I used this it allowed me to play my all time fav on vista
it emulates DOS and allows you to play the games through the emulator
Heres the download link : DOSBox, a x86 emulator with DOS
If you have any probs ask me and ill help you to the best of my ability:)
    Compaq
    Intel duo-core 2.6 Ghz
    1GB RAM
    GeForce 7500 LE
    32-bit
    one hardrive with 360GB space
    8MB
Hyzoran
I had the same exact problem, but the solution in my case was compleatly stange and unexpected, I was running the game in windows 95 compatability mode and the game didnt work. But what i did to fix this was not run it in compatability mode at all, and WTF..... it works!!!
dommyuk
I think I've fixed it, or atleast it has for me, you'll need the Application Compatability Toolkit. You may have noticed that none of the 'fixes' it already has works for it, so you'll need to make your own. Click the Fix button and fill out the name and the destination of the executable. You'll want Keeper95 or Deeper95 if you want Deeper Dungeons and select next. Now you'll be at the compatability screen, select none and then next. Now you'll be at the Compatability Fixes section, scroll down to find 'ForceDirectDrawEmulation' and activate it. Now use the Test Run button and the game should run, but the colors might be all messed up. Exit the game and click next and finish on the next screen. If the colours were all screwed up, find the Dungeon Keeper or Deeper Dungeons executable and right click on it and select properties. Go to the compatability tab and turn on 'Run in 256 colours' and 'Run at 640x480 screen resolution'. Then go back into the Application Compatability toolkit and select the fix you previously created then click run and it should work. Only problem I have is the map and 'after mission' score scrolls to fast, so you may need CPUkiller or something similar. If it still doesn't work turn on XP SP2 compatability, which may fix it.
