If you have problems with your email, one of the first things you should do is check the settings in your email client and compare them with the settings that can be found on your ISP/Email provider's website. Sometimes, the port numbers change, and you might need to update your settings to the current ones. If nothing has changed, and all your settings are correct according to the website, then it might possibly be an issue at their end as opposed to a problem on your machine. Try accessing your emails through the web interface instead of your email client for a while. Although the web interface will allow you to send and receive emails, it is usually only a basic interface offering limited functionality. Because of this, keep checking the client so that you can resume using it when service is restored.
(Copied from my post over at SF)
- Dwarf Dwf/11/2012 r09/2013
- Intel Core-i5-3570K 4-core @ 3.4GHz (Ivy Bridge) (OC 4.2GHz)
- ASRock Z77 Extreme4-M
- 4 x 4GB DDR3-1600 Corsair Vengeance CMZ8GX3M2A1600C9B (16GB)
- Graphics Card(s)
- MSI GeForce GTX770 Gaming OC 2GB
- Realtek High Definition on board solution (ALC 898)
- ViewSonic VA1912w Widescreen
- 1440x900
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
- PSU
- XFX Pro Series 850W Semi-Modular
- Case
- Gigabyte IF233
- Cooling
- 1 x 120mm Front Inlet 1 x 120mm Rear Exhaust
- Microsoft Comfort Mouse 3000 for Business (USB)
- Microsoft Comfort Curve Keyboard 3000 (USB)
- NetGear DG834Gv3 ADSL Modem/Router (Ethernet) ~4.0 Mb/s (O2)
- Other Info
