enable wireless router
S
smeg ed
Hi there all
Got a new laptop and trying to get it wireless with a belkin router, when i
go to network and sharing i can see the wireless icon there but it is not
conneted. how do i do this? Tried everything and i am about to crack up.
Friend reckons you must be conected with wires on one computer before you can
connect wireless for other computers (laptops). I only got one laptop which
i want wireless is this ok.
Cheers
R
Robert L. \(MS-MVP\)
Who setup the wireless router? You need the security inroamtion of the
router to setup your wireless.
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"smeg ed" <smeg ed@xxxxxx> wrote in message
news:9658A136-8AB9-4AB7-85A4-40EB23614F67@xxxxxx
> Hi there all
> i
> can
> which
> Cheers
C
Chuck [MVP]
On Tue, 5 Feb 2008 05:57:13 -0800, smeg ed <smeg ed@xxxxxx>
wrote:
>Hi there all
>Cheers
You can setup a WiFi router, using a WiFi connected client, it's just not a good
idea. Most modern laptop computers come with an Ethernet port. Do you lack the
port, or the cable?
<http://nitecruzr.blogspot.com/2005/11/setting-up-wifi-lan.html#AccessPoint>
Cheers,
Chuck, MS-MVP 2005-2007 [Windows - Networking]
Paranoia is not a problem, when it's a normal response from experience.
My email is AT DOT
actual address pchuck mvps org.
M
Mick Murphy
You have a belkin router and a laptop.
1. Connect your laptop to the router with a Cat5 cable(Ethernet cable)
2. log into your router.
3. Set up your internet connection(username and passoword, if this is the
only computer on your network).
You will see the different sections when you are there!
4. Set up a SSID Network and WPA or WPA2 Security Key.
5. Save all changes.
6. disconnect cable from laptop.
7. in vista, go to start>connect to> your wireless network should show.
You don't provide enough info as to whether yours is the sole computer, or
not.
"smeg ed" wrote:
> Hi there all
> Cheers
S
smeg ed
Thanks for that, I have done all this but when i search for wireless device
it cant find any, never mind i got this guy coming today (charging me 35
quid) to sort it out will post what i did wrong if anything. Thanks again.
New to this game so i will prob need help in future. Lucky you lot are out
there and so helpful.
smeg ed
> not.
> "smeg ed" wrote:
> > Hi there all
> > Cheers
S
smeg ed
Hi Mick
Had enough and got this guy to sort out problem, laptop was wireless when
the guy was here problem now is i unplugged the router to plug it in a more
permenant place when i switched all back on again cant go wireless again.
What is happening here i'm crackng up? when wired it is telling me i am
connected to wireless but soon as i unplug and scan for wireless device it
cant find any networks.
I have the laptop as the sole one on the internet.
Cheers
> not.
> "smeg ed" wrote:
> > Hi there all
> > Cheers
