Enabling and Disabling animations easily;
W
WernerG
I am trying to implement a way where I can easily enable and disable
animations via application configuration. I came up with the following
solution...
public class AnimationControl
.....#region const
.........public static bool enableAnimation = false;
.....#endregion
.....public static void Begin( UIElement target, DependencyProperty property,
AnimationTimeline timeline )
.........if ( enableAnimation )
.............target.BeginAnimation( property, timeline );
.........else
.............LocalValueEnumerator en = timeline.GetLocalValueEnumerator();
.............en.Reset();
.............while( en.MoveNext() )
.................if ( en.Current.Property.Name == "To" )
.....................target.SetValue( property, en.Current.Value );
This works fine. However, animations that have completed events associated
with them obviously wont work with this trick. Is there any way to manually
signal a AnimationTimeline to fire that event?
Thanks
W
