encrypted hard disk
Hi, I need help with my laptop i can access to it i'm gotting a mensage it say:
your sistem it's been lockecd and the data in the hard disk is currently inaccessible. Your hard disk it's encrypted, therefore you need to enter an administrator password in order to access the data.
The domain that you are trying to access is not valid or it's been disabled by your administrator, pleae contact your sistem administrator for support.
Unable to load windows, number of attempts excceded.
does somebody know what can i do? thanks' emerino:sarc:
MrNeeds
PC Geek
theres only one option if you cannot remember your password, flatten the laptop with the recovery cd you got with the laptop. If it is yours of course, you will have the recovery disc to hand :) enjoy
the pc isn't my it's my friend's pc, she did buy this pc but she locked it by accident.
i will ask her if she have the recovery cd. is there an other way to acceses to this pc?:huh:
SIW2
Hi Emerino,
Have a look at this first
http://www.vistax64.com/tutorials/102005-reset-user-account-password.html
From what you say , you may need to do this
D/l this .iso
PCLoginNow, Download PCLoginNow
burn to cd with this - do not format cd-if autoplay pops up, just close it.
View attachment Burn CDCC.zip
Boot from the cd. It finds your o/s-highlight it and click Next. It finds the accounts - highlight the Admin account and click Next. Tick "Password is empty" click Next - it asks if you want to do anything else, say No.
Remove the cd. Reboot the pc.
Hope it helps
SIW2
EDIT: How to boot from cd/dvd :
You may find you have the option of a pop-up boot menu - watch the black screen with white writing when you start the machine - may say something like:
F2 for setup
F11 for boot menu ( your F numbers may be different)
Press the one for boot menu - when it pops up, arrow to cdrom drive , put dvd in press Enter. It will ask you to press any key to boot from cdrom - press Enter again.
If you don't get that option , see this
How to Set BIOS to Boot from CDROM - www.hiren.info
http://www.hiren.info/pages/bios-boot-cdrom
Hi Emerino,
D/l this .iso
Remove the cd, reboot the pc
Hope it helps
SIW2
thanks' for your support but i can't acces to my boots.
