Enumerating Uninstall Key from Registry
G
greatbarrier86
My plan is to be able to pull just the names of all the installed programs. I
know Win32_Product will get the ones installed by windows installer, but not
the ones installed w/o it. I assume i need to start with
hklm:Software\Microsft\Windows\CurrentVersion\Uninstall, but i dont know
where to go from there. I know i have to somehow parse the Name string, but
i'm not sure how.
S
Shay Levi
This will list all uninstall applications name
dir HKLM:\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall | foreach {[io.path]::GetFileName($_)}
Shay
http://scriptolog.blogspot.com
> programs. I know Win32_Product will get the ones installed by windows
> installer, but not the ones installed w/o it. I assume i need to start
> with hklm:Software\Microsft\Windows\CurrentVersion\Uninstall, but i
> dont know where to go from there. I know i have to somehow parse the
> Name string, but i'm not sure how.
G
greatbarrier86
that works...but it lists some of them by GUID. how do i actually get inside
the key itself?
> Shay
S
Shay Levi
Also filters out GUIDs and KBs
$kb = "KB[0-9]{6}.*"
$guid = "\{[0-9a-fA-F]{8}(\-[0-9a-fA-F]{4}){3}\-[0-9a-fA-F]{12}\}"
$names = dir HKLM:\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall |
select {[io.path]::GetFileName($_.name)}
$names | where {$_ -notmatch "$guid|$kb"}
Shay
> Shay
>> start with hklm:Software\Microsft\Windows\CurrentVersion\Uninstall,
>> but i dont know where to go from there. I know i have to somehow
>> parse the Name string, but i'm not sure how.
G
greatbarrier86
Thank you very much!
> Shay
> > Shay
