Environment Variables questions and format questions
thebat1
I have a
HP Pavilion dv7t-1000 CTO Entertainment Notebook PC
64bit with Windows Vista Home premium
Recently I had a friend take it and wipe it to start fresh.
when I got it back it is still pointing to a bizarre path..?? (which is one of the reasons I wanted to start fresh. It points to:
PATH
%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;C:\Program Files (x86)\CyberLink\Power2Go;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\
PATHEXT
.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
why would this be the case? When I got it back I see that some things like my extra monitor was already installed.. (Before I even hooked it up??) and some folders I had renamed example folder.OLD was still here. (and many other things that lead me to believe it did not get formatted correctly. (and could still have virus?):cry:
He used my factory disks. (which I do have)
can anyone advise me on what is going on?
thanks so much!!
    HP m9400t
    2 Quad CPU Q6700 @2.66GHZ 2.67 GHz
    unfortunately what ever HP put here... Wont do that again..
    4 gig
    Gforce 9300 GE
    Realtek High Def
    Samsung SyncMaster T24ooHD digital and Acer AL2216W
MilesAhead
Eclectician
I've had a bunch of HP machines. But I never used the restore. I'm not sure if it formats or just installs over what's there. It may leave files and folders that are in subfolders of programs that come bundled with the machine assuming it's data or something. The path looks fine to me. That %SystemRoot% stuff is just a way to use environment variables in case the system is not installed on C:\Windows.
If you really just want the OS and not the bundled software see the threads about ISO download for Vista. You can evaluate for 90 days perfectly legally. There are also tutorials how to extend the evaluation by 30 days.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
thebat1
No I have never used RESTORE myself... I was talking about re installing windows .. not roll back to a earlier time as I always have that disabled. (that causes huge problems...)
I thought the path should be set to program files and program files (x86) for 32 bit programs?
also why would drivers for hardware that I have not hooked up already be installed?
I really dont want a 90+ day trail of windows... I already paid for this one...
(Unfortunately I did not realize it was crippled version..(HP's version) of windows...
I had been spoiled to having my own CD and a real copy of Windows not pre made version..
(I know I started different than most.. LOL)
not being able to mess with video settings in the bios and having all this bloatware is new to me and I am not happy with all that...I was shocked to see what MOST people get when buying a pre made pc...
anyway...
thanks for replying!
    HP m9400t
    4 gig
    Gforce 9300 GE
    Realtek High Def
MilesAhead
Eclectician
It's been awhile since I ran the HP program to install the bundled software. I.m not familiar with the options. I would think there would be a clean reinstall where the disk would be formatted. But perhapd there;s a no format option that your friend used. There are HP support forums where you should be able to get an answer specific to your HP model.
Hopefully somebody with a simialr HP will chime in here.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Ztruker
Not true. As each program is installed, it can add itself to the PATH but the system doesn't do this automatically.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB
    Seagate ST2000NM001 2TB
    Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot)
    Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
LMiller7
Power User
PATH
Nothing unusual here.
PATHEXT is also quite ordinary.
The PATH environment variable specifies a number of folders that will be searched when you enter a command on the command line. This saves you from having to enter the full path. A path to the program files folder itself would be pointless as it does not contain any files, only folders. An application may add to the path variable if it wishes. Most do not.
thebat1
Ok thanks everyone...about the path clarification.... Appreciate that..:)
    HP m9400t
    4 gig
    Gforce 9300 GE
    Realtek High Def
