Error Code: 0x8007045D
D
Drktitan
I am trying to install Vista Business which it recommended for my computer
but it gets to 8% on Copying Windows Files and then the Error occurs. I
have tried upgrade and clean install neither will work. I am running Xp Pro
Sp2 and has been completely upgraded. Can anyone help out? My RC1 build
works fine. I dont know any other files I would need to install it.
A
Andre Da Costa[ActiveWin]
Are you launching setup using a Virtual disk drive software or you burnt the
DVD? If you burnt it to a DVD make sure its at the lowest speed 1 to 2x. If
that does not work try extracting the contents of the ISO to a folder and
launch setup from there.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog/cns!E8E5CC039D51E3DB!9709.entry
"Drktitan" <Drktitan@discussions.microsoft.com> wrote in message
news:AF96A290-EC3D-4983-BC34-83C91E2BD7D0@microsoft.com...
> Pro
