error code 80070641
Hi everyone
First time posting to this forum, hope someone out there can help me.
I've 12 important updates that I've tried installing but keeps failing and gives an error code 80070641.
I've tried the Fix-it tool in windows with no luck, also ran sfc /scannow which informs me that I have corrupt files that it could not fix.
I have also checked windows installer is set to automatic and is started.
Any ideas folks???
    ACER ASPIRE 5536
    AMD ATHLON (TM) X2 DUAL-CORE QL-64 2.10 GHz
    3.00GB
richc46
tom982
٩(͡๏̯͡๏)۶
Hello Bill and welcome to the forums :party:
In addition to Richard's excellent advice, can you copy and paste the contents of this log file for us please?
C:\Windows\Logs\CBS\CheckSUR.persist.log
This should shed some light on your problem :)
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
Hi richc64
Thanks for your advice. I changed my updater to "check for updates but let me choose whether to download and install them" and then tried one update at a time and they all failed giving the same error code for each one "80070641" below I've listed the updates in question, just in case that might help.
Or maybe I didn't follow your advise correctly??? Not that computer I T savvy:confused:.
Really grateful for your help and advice.
Security Update for Microsoft .NET Framework 3.5 SP1 on Windows XP, Server 2003, Vista, Server 2008 x86 (KB2604111)
Download size: 946 KB
Security Update for Microsoft .NET Framework 4 on XP, Server 2003, Vista, Windows 7, Server 2008 x86 (KB2604121)
Download size: 22.9 MB
Security Update for Microsoft .NET Framework 4 on XP, Server 2003, Vista, Windows 7, Server 2008 x86 (KB2656368)
Download size: 1.9 MB
Security Update for Microsoft .NET Framework 4 on XP, Server 2003, Vista, Windows 7, Server 2008 x86 (KB2656405)
Download size: 8.8 MB
Security Update for Microsoft Office 2007 suites (KB2596672)
Download size: 997 KB
Security Update for Microsoft Office 2007 suites (KB2596792)
Download size: 1.7MB
Security Update for Microsoft Office 2007 suites (KB2596880)
Download size: 2.0 MB
Security Update for Microsoft Office 2007 suites (KB2597162)
Download size: 7.4 MB
Security Update for Microsoft Office 2007 suites (KB2597969)
Download size: 1.2 MB
Security Update for Microsoft Office Excel 2007 (KB2597161)
Download size: 8.5 MB
Security Update for Microsoft Office Word 2007 (KB2596917)
Download size: 8.9 MB
Security Update for Microsoft Silverlight (KB2690729)
Download size: 6.0 MB
    ACER ASPIRE 5536
    3.00GB
richc46
Hi Tom
Was this what you were looking for?
Checking System Update Readiness.
Binary Version 6.0.6002.22574
Package Version 14.0
2012-05-13 10:37
Checking Windows Servicing Packages
Checking Package Manifests and Catalogs
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
(f) CSI Payload File Missing 0x00000000 tasklist.exe x86_microsoft-windows-tasklist_31bf3856ad364e35_6.0.6001.18000_none_284332315a51a48f
(f) CSI Payload File Missing 0x00000000 taskkill.exe x86_microsoft-windows-taskkill_31bf3856ad364e35_6.0.6001.18000_none_257dff055c108bff
(f) CSI Payload File Missing 0x00000000 taskschd.dll x86_microsoft-windows-taskscheduler-client_31bf3856ad364e35_6.0.6001.18000_none_43fa48149e4fe190
(f) CSI Payload File Missing 0x00000000 taskmgr.exe x86_microsoft-windows-taskmgr_31bf3856ad364e35_6.0.6001.18000_none_14622f2da933f0c7
Summary:
Seconds executed: 5102
Found 4 errors
CSI Payload File Missing Total count: 4
    ACER ASPIRE 5536
    3.00GB
tom982
٩(͡๏̯͡๏)۶
Hi Tom
2012-05-13 10:37
Checking Packages
Summary:
Found 4 errors
Hi Bill,
Yes, that's the one! Good job. Before we move on to a fix, I would like to double check these files with the results from the SFC scan. Can you please go to this tutorial:
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
Near the top of the page, you will see a yellow "Tip" box with two sets of instructions in it. Could you follow step 2 only please? This will generate a file, sfcdetails.txt, which I would like you to post the contents of for us to have a look at.
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Hi Richard
Thanks again for your help and advice, I tried the first and second fixes you advised and rebooted after each one before attempting to update but unfortunately with the same result......failed.
I only have a mobile dongle for internet access so downloading is very slowwwww and it got pretty late by the time I'd completed your first two suggestions. I will attempt the third fix shortly.
But I'm going to respond to Tom's request first.
Kind regards
    ACER ASPIRE 5536
    3.00GB
richc46
You can follow the given suggestions in the manner that is best for you. Both Tom and I just want your problem to be solved.
Hi Tom
Thanks for your advice but unfortunately I was unable to complete the task, I downloaded the 7-zip file and that's where things started to go wrong. It wasn't the same as the one in the screenshot....instead of a Compatibility tab my one had a Share tab. So I looked at how to change this and was taken into the registry, I followed the steps and the very last one again on mine wasn't the same as the screenshot so I backed out before I made matters worse!! The instructions were to make changes in the registry, something I know nothing about, especially when the (layers) file wasn't there. Sorry:confused:
Is there any other way to get the info you require?
Kind regards
    ACER ASPIRE 5536
    3.00GB
tom982
٩(͡๏̯͡๏)۶
Hi Tom
Kind regards
Hello Bill,
I'm so so sorry! I had a typo in those last instructions. What I meant to say was choose step 1 only.
Hi Tom
2012-05-13 10:37
Checking Packages
Summary:
Found 4 errors
Hi Bill,
Near the top of the page, you will see a yellow "Tip" box with two sets of instructions in it. Could you follow step 1 only please? This will generate a file, sfcdetails.txt, which I would like you to post the contents of for us to have a look at.
Tom
Sorry :o
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Hi Richard
Tried some of the options in that third suggestion of yours but sorry to say still no luck installing afterwards. Another update was added to the list but this one was successfully installed;
Definition Update for Windows Defender - KB915597 (Definition 1.127.201.0)
Why can this one install but not the others?
I'm most grateful for your time, help and advice.
Kind regards
Bill
    ACER ASPIRE 5536
    3.00GB
Hi Tom
Followed the steps to the letter in option 1 but when I closed the elevated command prompt and checked my desktop there was no sfcdetails.txt file.
Kind regards
Bill
    ACER ASPIRE 5536
    3.00GB
richc46
Post number 4.......:confused: what one was that? I looked at the link you sent with your last post but unsure what you'd like me to do.
    ACER ASPIRE 5536
    3.00GB
richc46
The relevant part is here:
Please copy the C:\Windows\Logs\CBS folder to your Desktop, right click on it > Send to > Compressed (zipped) folder, and upload the new file which is created on your Desktop here
tom982
٩(͡๏̯͡๏)۶
I'll take a step back here, it's getting confusing having two people helping simultaneously and you're in much better hands with Rich :) I'll stay subscribed to this thread and I'll post if I spot anything.
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
richc46
Hi everyone
Any ideas folks???
TY Tom, but you are too generous. I helped obtain the SFC, to see if there were problems others could solve.
Without any other input from you or others, my next suggestion is a Repair install.
http://www.vistax64.com/tutorials/88236-repair-install-vista.html?filter[11]=Performance Maintenance
tom982
٩(͡๏̯͡๏)۶
Hi everyone
Any ideas folks???
Okay, I'll give it a quick go replacing these files manually :) As confirmed by your CBS log, I think these are the culprit files:
taskkill.exe" of Microsoft-Windows-TaskKill, Version = 6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file is missing
2012-05-13 08:07:59, Info CSI 000004b7 [SR] Cannot repair member file [l:24{12}]"tasklist.exe" of Microsoft-Windows-TaskList, Version = 6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file is missing
2012-05-13 08:07:59, Info CSI 000004b8 [SR] Cannot repair member file [l:22{11}]"taskmgr.exe
System Look
Please download SystemLook from one of the links below and save it to your Desktop.
  • Double-click SystemLook.exe to run it.
  • Copy the content of the following codebox into the main textfield:
    Code:
    :filefind
    taskkill.exe
    tasklist.exe
    taskmgr.exe
  • Click the Look button to start the scan.
  • When finished, a notepad window will open with the results of the scan. Please post this log in your next reply.
Note: The log can also be found on your Desktop entitled SystemLook.txt
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
