Error Code 8007312
J
On 7/30/07 I asked a question that did not get answered 'disk managment
computer mangment'. Now I am getting error 8007312 and windows update will
not run.
I wrote on Monday
"Unable to Connect to Virtual Disk Service
diagnostic
I have a Vista Home Pre. Pc that had a sata data drive go bad so i removed
it and ordered a new hard drive. While I am waiting for the disk I need to
press F1 to by pass the disk during boot up. After Vista starts I see all my
other disk thruough windows explorer but if I check them through computer
mangment/disk managment I get Unable to Connect to Virtual Disk Service.
I do not know if Vista is damaged or I need to start a service or even the
bois F1 is effecting it but I thought I better ask. Is there something I need
to do to get disk managment working? Also can I run some type of diagnostic
that will tell me what else is wrong?
Thanks Jon"
Please point me in the right direction if you can not answer.
Thanks again Jon
S
Steve Pearce
On Wed, 1 Aug 2007 06:14:00 -0700, Jon <Jon@discussions.microsoft.com>
>not run.
I think there is missing digit in the error code, they are usually 8
digits long.
J
Sorry it is 80073712
> >not run.
> digits long.
J
I just tried sfc /scannpw as and admin and it only got to 7% and gave the
message
'Windows Resource Protection could not perform the requested operation'
Should I do a full repair?
Please Help Jon
> >not run.
> digits long.
D
dean-dean
Given that the System File Checker found errors
that it couldn't repair, a re-install of Vista may not be such a bad thing,
in the long run.
You can re-install Vista, using the Upgrade option.
This will maintain your user settings and programs. See
"Upgrade procedure" in this article:
http://support.microsoft.com/kb/918884
Insert and start the DVD from Your Desktop (don't boot the DVD), that is,
when you are Logged On to Windows.
When confronted with the "press any key.." prompt, after the computer
restarts, don't press any key, and Setup will continue...
"Jon" <Jon@discussions.microsoft.com> wrote in message
news:D8BB7EBF-C479-4810-8856-B271C525623E@microsoft.com...
> message
> Please Help Jon
>> >will
>> >not run.
>> digits long.
J
I will try
> in the long run.
> > message
> > Please Help Jon
> >> >will
> >> >not run.
> >> digits long.
D
dean-dean
Well, the fact that the System File Checker ground to a halt after such a
short time, indicates, to me at least, more problems down the road.
You could try the fix for Windows Update, offered here:
http://support.microsoft.com/default.aspx/kb/931712
If that fixes Windows Update, then try the sfc /scannow command again (Run
as Administrator)....
news:25A85A1B-9523-4B19-BEEE-9C1D160EE903@microsoft.com...
>I will try
>> thing,
>> in the long run.
>> is,
>> >the
>> > message
>> > Please Help Jon
>> >> >managment
>> >> >will
>> >> >not run.
>> >> digits long.
J
#8
I did the reinstall "upgrade" and the Windows update works and disk manger.
The only thing wrong is my sound is off, which was not a problem before.
Device manger see my sigma sound but the sound link say No devices available.
I tried to uninstall and reinstall but it did nothing in device mgr also
tried to updating the driver. Any ideas?
> >I will try
> >> thing,
> >> in the long run.
> >> is,
> >> >the
> >> > message
> >> > Please Help Jon
> >> >> >managment
> >> >> >will
> >> >> >not run.
> >> >> digits long.
D
dean-dean
#9
Well, it seems as if it's not one thing, then it's another. Bummer. Try
this first. Right-click the Volume icon, and choose Playback Devices. On
the Playback tab of Sound, right-click an empty spot of the window, and put
a checkmark next to "Show Disabled Devices" and
"Show Disconnected Devices". From there, if Speakers shows up, right-click
the Speakers icon to enable.
Then Double-click the Speakers icon. On the Enhancements tab, put a check
next to "Disable all sound effects", then click Apply. On the Advanced tab,
click on Restore Defaults, and make sure both check-boxes, under Exclusive
Mode, do have a check mark. (Apply, OK).
If none of that pans out, or there is no Sound control panel at all, post
back your Computer make and model names, and the name of your sound device
in Device Manager, along with the version number of the driver.
news:E1F8B774-14E1-4C39-9D37-ED5EEF6A1D83@microsoft.com...
> available.
>> (Run
>> >I will try
>> >> thing,
>> >> in the long run.
>> >> is,
>> >> >the
>> >> > message
>> >> > operation'
>> >> > Please Help Jon
>> >> >> >managment
>> >> >> >update
>> >> >> >will
>> >> >> >not run.
>> >> >> 8
>> >> >> digits long.
I had to unisatall advanced the driver and I installed leastest one and work.
Thanks
> > available.
> >> (Run
> >> >I will try
> >> >> thing,
> >> >> in the long run.
> >> >> is,
> >> >> >the
> >> >> > message
> >> >> > operation'
> >> >> > Please Help Jon
> >> >> >> >managment
> >> >> >> >update
> >> >> >> >will
> >> >> >> >not run.
> >> >> >> 8
> >> >> >> digits long.
D
dean-dean
#11
Okay! Great, I think your set. Thanks for posting back, and good luck....
I daresay if you ran sfc /scannow at this point, you should be given the
text message "Windows Resource Protection did not find any
integrity violations".
news:D4AAC5A4-9A88-473F-AB91-4FF66C0CCDDA@microsoft.com...
>work.
> Thanks
>> On
>> put
>> right-click
>> check
>> tab,
>> Exclusive
>> device
>> >manger.
>> > before.
>> > available.
>> > also
>> >> such a
>> >> (Run
>> >> >I will try
>> >> >> bad
>> >> >> thing,
>> >> >> in the long run.
>> >> >> that
>> >> >> is,
>> >> >> computer
>> >> >> >gave
>> >> >> >the
>> >> >> > message
>> >> >> > operation'
>> >> >> > Please Help Jon
>> >> >> >> >managment
>> >> >> >> >update
>> >> >> >> >will
>> >> >> >> >not run.
>> >> >> >> usually
>> >> >> >> 8
>> >> >> >> digits long.
Do you feel I should just to be sure?
> >work.
> > Thanks
> >> On
> >> put
> >> right-click
> >> check
> >> tab,
> >> Exclusive
> >> device
> >> >manger.
> >> > before.
> >> > available.
> >> > also
> >> >> such a
> >> >> (Run
> >> >> >I will try
> >> >> >> bad
> >> >> >> thing,
> >> >> >> in the long run.
> >> >> >> that
> >> >> >> is,
> >> >> >> computer
> >> >> >> >gave
> >> >> >> >the
> >> >> >> > message
> >> >> >> > operation'
> >> >> >> > Please Help Jon
> >> >> >> >> >managment
> >> >> >> >> >update
> >> >> >> >> >will
> >> >> >> >> >not run.
> >> >> >> >> usually
> >> >> >> >> 8
> >> >> >> >> digits long.
D
dean-dean
#13
It can't hurt. At least you will know how things stand in that department
as to your re-install.
news:9F3D6DA9-AC1A-443E-A4EF-4CAA54651D87@microsoft.com...
>> luck....
>> >work.
>> > Thanks
>> >> Try
>> >> On
>> >> and
>> >> put
>> >> right-click
>> >> check
>> >> Advanced
>> >> tab,
>> >> Exclusive
>> >> post
>> >> device
>> >> >manger.
>> >> > before.
>> >> > available.
>> >> > also
>> >> >> such a
>> >> >> again
>> >> >> (Run
>> >> >> >I will try
>> >> >> >> bad
>> >> >> >> thing,
>> >> >> >> in the long run.
>> >> >> >> DVD),
>> >> >> >> that
>> >> >> >> is,
>> >> >> >> computer
>> >> >> >> >and
>> >> >> >> >gave
>> >> >> >> >the
>> >> >> >> > message
>> >> >> >> > operation'
>> >> >> >> > Please Help Jon
>> >> >> >> >> >'disk
>> >> >> >> >> >managment
>> >> >> >> >> >windows
>> >> >> >> >> >update
>> >> >> >> >> >will
>> >> >> >> >> >not run.
>> >> >> >> >> usually
>> >> >> >> >> 8
>> >> >> >> >> digits long.
