ERROR: hl2.exe has stopped working
W
wb0d
I just got a new computer with vista home premium on it. I installed steam,
updated my graphics card drivers, and installed cs:s and it worked great for
a few days. But now, whenever I try to launch cs:s, it just takes me to the
menu screen and then crashes, and I get a message that says "hl2.exe has
stopped working". I reinstalled steam and cs a few times. Then I heard this
was an issue with dep, and I was told that I needed to go to the command
prompt, run as administrator, and type in a command that disabled dep, but
I'm still getting the problem. I seriously don't know what to do. Can anyone
help?
D
Dale M. White
Steam and HL2 is are Vista compliant or at least Steam supports vista. I'm
not sure where the DEP issue comes in. I didn't have to do anything with DEP
to get Steam installed and HL2 (and the add-ons) to work.
I'd be more out to look at any other updates or software add that's you've
done to the system. Any tweaks to the firewall, Maybe Windows Defender. Any
anti-Virus software. I'm guessing something else changed.
One thing you could try, is to create another user account, log-in and try
to play with that account. Over in the FEAR forums there was a guy who could
patch the game and when he tried that it worked. If it doesn't work, then
you might have a registry corruption issues or something else going on in
your profile that hindering HL2
andrew833
i dont have a answer to that but the same happened to me its because of AIM it has a virus. there is a file i cant find but if i do ill post it:)
NEVER DOWNLOAD AIM ON VISTA HL2.exe's WILL NOT WORK
SO TELL EVERY ONE TO NOT DOWNLOAD AIM PLZ:sleepy:
pay101
I'm having the same problem, I have vista ultimate 32bit, and i get the same exact message. I'm trying to uninstall my sisters stupid aim6 to see if this works....
T
Tim
Are you overclocking? i had the same message for a while. i have vista
ultimate 32. When i raised my vcore or lowered my clock speed to a more
stable level, it worked.
pay101
I've never overclocked this :/ it does this for HL2, CS:S, and all of the rest of my steam games.... this also happens to A LOT of games with any form of a physics engine, if it has anything with physics, (besides ragdolls) it says "blah blah blah.exe has stopped working" usually hl2.exe.
joshdmorris
I think it has to do with AIM 6's security update. I hadn't gotten on AIM in a very long time and today i got on and installed the update and now i get the HL2 error on all my games. Has anyone figured out how to fix this? My virus scanner doesn't detect any coded viruses inthe files, so what else could it be? HELP!
C
Chris
Has nothing to do with AIM. I had the same problem and have never had
AIM installed on my system. Something to do with STEAM. had to
reinstall steam to get everything working good.
Adrole
I had the same problem when I got a new computer with Vista Businiss x64 opening Portal or TF:2 after a few seconds it would either just close or crash.
It did not start like that though for about 2 days it worked fine, then it would sometimes crash after playing for a few minutes now it crashes before it opens.
I actually just set it as an exception in the DEP for steam which might have helped, still need to test it though.
But here is how you can try the same.
Control Panel > System And Maintenance > System > Advanced System Settings > On the Advanced tab go to setting under Performance then Data Execution Prevention.
You can either try setting it to "Turn on DEP for essential windows programs and services only"
Or try turning DEP on for all programs and add Steam as an exception.
I haven't tested if it's fully worked yet, but Portal does open now.
t0m0wnz
I have exactly the same problem except when I try going on cs with my account it crashes and says hl2 has stopped working but when i go on my friends account it works perfectly fine I dont know why it does this
S
stupidbum
I have the same exact problem, and i've uninstalled everything that the
forums on steam said to uninstall such as my google tooolbars, and my
avg 7.5 . and this has been happening for a while. Yesterday i was at my
friends house and we signed onto my accout to play garrys mod and it
worked on his computer. but i dont know whats wrong with my computer. i
have windows vista home edition.
if someone can help me please message me back soon, im so freaking
bored and pissed because i cant play cs:s.
please message me back soon, i need some help
stupidbum
http://www.vistaheads.com
A
Andy [YaYa]
Need system specs, make/model. Is this a Vista Upgrade? Did you buy the
system with Vista on it? At any time did Steam work normally? Did you
install any other applications recently? Did you try deleting all the files
in your steam folder (except for the big steamapps folder) and try re-
installing the Steam client from http://www.steampowered.com?
No reason you'd need to remove Google or AVG. No idea why you'd have too.
Also you didn't quote the original problem, and i'm on Usenet, so let us
know what the original issue was.
-A.
S
stupidbum
sorry i left so many gaps in my description. ok ill start over
my specs are :
Windows vista home basic
im using a dell inspiron 4305
with an intel(R) core(TM)2 CPU 4400 @ 2.00 GHz 2.00 GHz
2046 MB of RAM
32- bit operating system
^^ those are my specs
my problem is that whenever i start up any game that i have on steam it
either crashed my whole computer and i have to reboot, or the game
crashes and an error message saying "hl2.exe has stopped working".
yes my steam games used to work perfectly fine.
and i uninstalled my google toolbars and avg 7.5 because on the steam
site it says that those things could cause it to crash...
yes i bought the system with vista on it.
i uninstalled all of my games and reinstalled them and they still didnt
work so i uninstalled steam all together and reinstalled steam and they
still dont work.
if you need any more info please let me know.
stupidbum
A
Andy [YaYa]
Sounds like you have a firm grasp on troubleshooting games, I guess I'll
point out the semi-obivous, if reinstalling steam doesn't help then
there's something else on your system, something you changed or
something that has changed that's causing the problem.
I would recommend running System Restore and rewinding your system files
to a date before all these problems started occuring.
You said you have an Inspiron 4305, but support.dell.com doesn't list
that model as a notebook or a desktop Inspiron model. I would suggest
going to Dell support online, find your system model in the Drivers and
Downloads are and make sure you get their latest drivers.
Note that these drivers aren't they newest, they are just the ones that
Dell supports. If you know your video card make/model, and your
motherboard chipset make/model you may consider getting video/chipset
drivers from the manufacturer directly. If you're not sure how, double
check your system model number or post your video card/chipset info
here.
If you disabled System Restore (why?), or if SR doesn't go back far
enough in time then you may end up simply reinstalling Vista. Something
installed or changed on your system causing the crashes. When HL2.exe
stops working does it generate an error log?
-A.
S
stupidbum
k i have no idea what your talking about, can you dumb that down a bit
so i can understand what the hell im doing?
stupidbum
A
Andy [YaYa]
I'll point out the semi-obivous, if reinstalling steam doesn't help
then there's something else on your system, something you changed or
You reinstalled Steam. That did not fix the problem, so it probably is
NOT Steam, there's something else wrong with your system.
files to a date before all these problems started occuring.
Click Start Orb, and type "System Restore"
You should get an icon in your programs list that says "System Restore"
This program is built into Windows XP and Vista, it can "Rewind" your
computer to an earlier point in TIME. Basically, say you install a
program and your computer starts having problems, you can use system
restore to UNDO whatever damage was caused to your system.
It does not effect your personal data, only programs.
Something installed or changed on your system causing the crashes.
When HL2.exe stops working does it generate an error log?
When you bring up System Restore, you have the option of using a
suggested point in time to rewind too, if you choose No, you can choose
from a calendar of dates where your system files were "remembered". Try
to figure out when you started having problems. choose a date close too
that point in time and try selecting it. Your system reboots, then you
can try the game again.
and Downloads are and make sure you get their latest drivers.
Go to http://support.dell.com
Click Drivers and Downloads
Find the model number of your system from this list, the model you
mentioned (Inspiron 4305) does not exist, so I'm guessing you typed it
incorrectly?
Once you find the model of your computer, you can find the drivers for
Chipset, Video, and Audio for your system. Download and install per the
instructions.
that Dell supports. If you know your video card make/model, and your
here.
Dell tests drivers before they post them, if you want newer drivers you
have to go to the makers of each piece of hardware in your computer,
Video cards are usually made by nVidia (http://www.nvidia.com), or ATi
(http://ati.amd.com)
If you go to their sites, find your video card you can get a newer
version of their drivers which might fix your problems. You can probably
skip this suggestion, for now.
You're trying to do something difficult over text based messasge board,
it's not going to be easy, if you have any friends in your area that
work in IT, or Geek Squad or do a LOT of video game playing on PC, you
should call them for help.
Worse case scenario, Dells come packaged with "Restore" discs, that wipe
your HD and reinstall your OS like it was when you first bought the
computer. If you do that, update Windows using Windows Update, then re-
install your games, it will probably fix the problem.
Good luck,
-A.
codeyh
When I added Local Service and Network Service to administrators... all my HL2 problems went away.
    Intel Xeon E3110
    Gigabyte EP35-DS3R
    OCZ OCZ2N800SR4GK PC2-6400 (2x2GB)
    eVGA nVidia GeForce 7900GT KO
    Seagate ST3120026A
    Seagate ST3300622AS
jackkkkinthebox
What do u mean when u say?
" When I added Local Service and Network Service to administrators... all my HL2 problems went away." Codey H
Can u give instructions for that please?
K
Kyle Guzman
steam problems
Does any one know what will happen if you reistall
steam, will it delete your friends list ??
