error: shut down pc when playing Blu-Ray movies
dford2201
Can anyone help me with this error message- A device attached to the system is not functioning. (0x8007001f)
When I play Blu-Ray movie it shut down pc.
The entry:
Code:
<C:\USERS\FORDMEDIA\APPDATA\ROAMING\MICROSOFT\WINDOWS\START MENU\PROGRAMS\CYBERLINK POWERDVD 8\UNINSTALL POWERDVD 8.LNK> in the hash map cannot be updated.
Context: Application, SystemIndex Catalog
Details:
Event Xml:
<Event xmlns="[URL]http://schemas.microsoft.com/win/2004/08/events/event[/URL]">
<System>
    CUST-MADE/FORD
    AMD PHENOM(tm)9850 QUARD PROCESSOR
    M3N-HD/HDMI-ASUS
    CORSAIR-4.00GB DDR2-8500
    NVIDIA GeFORCE9600 GT-XFX-SLI
    ONBORAD HIGH DEFINITION AUDIO DEVICE
    HP-w2007 WIDE LCD
    1680/1050-32BIT
    NVIDIA SPAN 465.77G0100
    THERMALTAKE-850WATTS
    THERMALTAKE-DH102/DIGITAL HOME SERIES
    N/A
    HID-COMPLIANT -MICROSOFT
    HID-COMPLIANT-MICROSOFT
    NVIDIA nFORCE 10/100/1000 MBPS
    ACPIx86-BASE PC
Dwarf
The Contemplator
Hi dford2201 and welcome to Vista Forums :party:
Are you having any other problems with your PC apart from it shutting down when attempting to play a Blu-ray disk? Is it possible that your screen resolution could be causing the problem, especially if you can play ordinary DVDs?
Here is the screen resolution from your specs.
Compare it with the requirements of PowerDVDv8 (taken from the Cyberlink website).
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
dford2201
dford2201:Hi=Dwarf;897770
I have recently played these movie title in the past;
BR:X-Men/The last stand
BR:Ghost Rider
BR:Fantastic4
BR:Spider-Man3
BR:SuperMan Returns
BR:Resident:Extinction
recently error
Log Name: Application
Source: Microsoft-Windows-Search
Date: 11/29/2008 12:59:41 AM
Event ID: 3013
Task Category: Gatherer
Level: Error
Keywords: Classic
User: N/A
Computer: FORDMEDIA-PC
Description:
The entry <C:\USERS\FORDMEDIA\APPDATA\ROAMING\MICROSOFT\WINDOWS\START MENU\PROGRAMS\CYBERLINK POWERDVD 8\UNINSTALL POWERDVD 8.LNK> in the hash map cannot be updated.
Details:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Search" Guid="{CA4E628D-8567-4896-AB6B-835B221F373F}" EventSourceName="Windows Search Service" />
<EventID Qualifiers="49152">3013</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>3</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2008-11-29T08:59:41.000Z" />
<EventRecordID>1160</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Computer>FORDMEDIA-PC</Computer>
<Security />
</System>
<EventData>
<Data Name="ExtraInfo">
Details:
</Data>
<Data Name="Entry">C:\USERS\FORDMEDIA\APPDATA\ROAMING\MICROSOFT\WINDOWS\START MENU\PROGRAMS\CYBERLINK POWERDVD 8\UNINSTALL POWERDVD 8.LNK</Data>
</EventData>
</Event>
    CUST-MADE/FORD
    M3N-HD/HDMI-ASUS
    HP-w2007 WIDE LCD
    1680/1050-32BIT
    N/A
    ACPIx86-BASE PC
dford2201
Think you very much for your input:Dwarf
PIONEER BD-ROM BDC-202 SCSI CdRom Device
But for some reason these title don't play at all on my PC
I updated my firmware for my BR-DVD drive still the same issue.
I have not change any hardware or add any new device.
I have played these movies title in the past;
BR:Ghost Rider=?
BR:Resident Evil:Extinction=?
BR:Fantastic4-Rise of the silver surfer=?
BR:Spider-Man3?
BR:X The Last Stand=?
BR:SuperMan Returns=?
    CUST-MADE/FORD
    M3N-HD/HDMI-ASUS
    HP-w2007 WIDE LCD
    1680/1050-32BIT
    N/A
    ACPIx86-BASE PC
