events, arguments, etc...
F
fixitchris
What is the method for a clicked item in a listview?
This is what I have $listview.add_click($function:onClick); BUT
function onClick($sender,$e) {Write-Host "click"};
$sender and $e seem to be NULL...???
I also tried to do this
$lvsi = New-Object windows.forms.listviewitem.listviewsubitem; BUT
that did not work?
Is there a good resource for dealing with events in PS?
Thanks
Chris
[reflection.assembly]::loadwithpartialname("system.windows.forms");
function onStart($sender,$e) {write-Host "service started"};
function onStop($sender,$e) {write-Host "service stopped"};
function onLoad($sender,$e) {$listbox.items.clear;get-wmiobject
win32_service |
%{$lv=$listview.items.add($_.name);$lv.subitems.add($_.state)} ;};
$window = New-Object windows.forms.form;
$window.Size = New-Object system.drawing.size @(220,600);
$window.Text = "Windows Services";
$window.FormBorderStyle = "FixedDialog";
$window.MaximizeBox= 0;
$button = new-Object windows.Forms.Button;$button.Text = "Start";
$button2 = new-Object windows.Forms.Button;$button2.Text =
"Stop";$button2.Left = 80;
$listview = New-Object windows.forms.listview;$listview.Top =
25;$listview.Height = 550;$listview.width = 210;$listview.view="Details"
$listview.MultiSelect=0;$listview.FullRowSelect =
1;$listview.Columns.Add("Name",125);$listview.Columns.Add("Status",60);
$lvi = New-Object windows.forms.listviewitem;
$button.add_click($function:onStart);
$button2.add_click($function:onStop);
$window.controls.add($listview);
$window.Controls.Add($button);
$window.Controls.Add($button2);
$window.add_shown($function:onLoad);
$window.ShowDialog();
B
Bruce Payette [MSFT]
We special-case this pattern so you don't need to declare any parameters.
When a scriptblock is used as an EventHandler, the sender is available in
$this and the event args are available in $_. Also, unless you also need to
use your handler as something other than as an event handler, there is no
need to define it as a function. Simple assignment to a variable is
sufficient.
$myHandler = {Write-Host "click sender: $this eventArgs: '$_'"}
$listview.add_click( $myHandler );
And to answer your other question, listviewsubitem is a nested class so you
have to use the '+' instead of a dot in the typename. (This is an artifact
of the representation that System.Reflection uses to represent the type
name.) So
$o = new-object System.Windows.Forms.listviewitem+listviewsubitem
works properly.
Windows PowerShell Technical Lead
Microsoft Corporation
"fixitchris" <fixitchris@discussions.microsoft.com> wrote in message
news:36CE5D46-69DE-4309-8C9B-31A9A3EF8A87@microsoft.com...
> that did not work?
> Thanks
> Chris
> win32_service |
F
fixitchris
I'm lost bruce....sometimes this works... most of the time it does not. I'm
not sure how to use the get_Item method either. i tried FOREACH through the
$this.items[], and just through $this ... I'm missing something. Thanks
$listview_handler= { $this.SelectedItems.item(0).text };
$listview.add_ItemSelectionChanged($listview_handler);
Exception getting "Item": "Exception calling "get_Item" with "1"
argument(s): "InvalidArgument=Valu
e of '0' is not valid for 'index'.
Parameter name: index""
At line:6 char:47
+ $listview_handler= { $this.SelectedItems.item( <<<< 0).text };
F
fixitchris
works beautifully
I guess I just needed to sleep on this...and I installed PS 1.0 as well.
$listview_handler = { if ($_.isselected -eq 1) {$lv =
$this.items[$_.itemindex]; Write-Host $lv.text } };
