<EventTrigger RoutedEvent="Button.Click">
H
Horst Klein
I have an idea, but I dont know how to realise it in XAML.
The online dokumentation gives not really an anser to my problem.
So, what will I do?
I try to call a custom Class, Property or Methode (with whatever it works)
with an Trigger (EventTrigger, ActionTrigger or whatever it works)
<Button x:Name="MyButton" Content="Button">
<Button.Triggers>
<UseMyClass>
</UseMyClass>
</EventTrigger>
</Button.Triggers>
</Button>
How can I do that?
Thanks for support.
Horst
K
Keith Patrick
You can call a custom property with:
<Setter PropertyName="" Value=""/>
There is a whole family of XSetter's
Not sure about methods, and classes are not executable per se unless you
count a main() method, in which case you wouldn't have to support "class
execution" anyway since method execution would cover it via the main().
T
thelemmings@gmail.com
Why not try something simple like:
<Button x:Name="MyButton" Content="Button" Click="MyOnClickMethod" />
With an implemention of MyOnClickMethod in your code behind:
void Click="MyOnClickMethod"(object sender, RoutedEventArgs rea)
// Do your stuff
Luc
> So, what will I do?
> <Button.Triggers>
> <UseMyClass>
> </UseMyClass>
> </EventTrigger>
> </Button.Triggers>
> </Button>
> How can I do that?
> Thanks for support.
> Horst
