Excel - "has stopped working" - WHY???
A
Does anyone know why nearly every time I close a file in Excel it stops
working? i keep getting the rather useful messages telling me it's stopped
working and then that it's restarting. It's driving me mad!!
R
Rick Rogers
Hi Alex,
A question better suited for an Office group, however see if this helps:
First, make sure you've downloaded and installed any updates from Office
Update:
http://office.microsoft.com/en-us/downloads/default.aspx
Second, click the Office Icon button at upper left, then Excel Options. Go
to Resources in the left column, then click on the line to "run microsoft
office diagnostics".
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"Alex" <Alex@discussions.microsoft.com> wrote in message
news:3524A4D6-887E-492C-A4DB-96BF110DB566@microsoft.com...
> stopped
A
Thanks Rick! However, I really should have mentioned that this happening
using Vista + Office 2003, not 2007.
Any ideas now?
Alex
"Rick Rogers" wrote:
> Hi Alex,
> Update:
> Best of Luck,
> > stopped
R
Rick Rogers
Hi Alex,
They both still apply, though the repair method for 2003 is different. IIRC,
you will find it under the Help menu in that version, or you can simply
insert the CD and use the repair option.
Best of Luck,
news:39AEC710-2B31-4D40-B61F-F751990B257A@microsoft.com...
> Any ideas now?
> Alex
>> Hi Alex,
>> Update:
>> Go
>> Best of Luck,
>> > stopped
A
I tried your solution but it's just happened again. All I did was open an
Excel document, print it, then close it again using the "x" in the top right
corner. I repeated this again but closed it using "File", "Exit" and Excel
stopped working again.
Any other ideas?
> Hi Alex,
> Best of Luck,
> > Any ideas now?
> > Alex
> >> Hi Alex,
> >> Update:
> >> Go
> >> Best of Luck,
> >> > stopped
R
Rick Rogers
No, not really, as I said initially this question would be better suited for
an Office group.
Best of Luck,
news:0A6B77C9-5D34-4254-87A8-F47ABB810822@microsoft.com...
> Hi,
> right
> Excel
> Any other ideas?
>> Hi Alex,
>> IIRC,
>> Best of Luck,
>> > happening
>> > Any ideas now?
>> > Alex
>> >> Hi Alex,
>> >> helps:
>> >> Office
>> >> Update:
>> >> Options.
>> >> Go
>> >> microsoft
>> >> Best of Luck,
>> >> > stops
>> >> > stopped
A
Thanks for your help. I'm not entirely sure where to go from here so will
just post the thread up again somewhere else. Thanks anyway.
> Hi,
> an Office group.
> Best of Luck,
> > Hi,
> > right
> > Excel
> > Any other ideas?
> >> Hi Alex,
> >> IIRC,
> >> Best of Luck,
> >> > happening
> >> > Any ideas now?
> >> > Alex
> >> >> Hi Alex,
> >> >> helps:
> >> >> Office
> >> >> Update:
> >> >> Options.
> >> >> Go
> >> >> microsoft
> >> >> Best of Luck,
> >> >> > stops
> >> >> > stopped
R
Rick Rogers
#8
Hi Alex,
You might try these for starters:
news://msnews.microsoft.com/microsoft.public.excel
news://msnews.microsoft.com/microsoft.public.excel.misc
Best of Luck,
news:4BD6CC21-788A-4065-B3A8-88F9E117FE33@microsoft.com...
>> Hi,
>> for
>> an Office group.
>> Best of Luck,
>> > Hi,
>> > an
>> > right
>> > Excel
>> > Any other ideas?
>> >> Hi Alex,
>> >> IIRC,
>> >> simply
>> >> Best of Luck,
>> >> > happening
>> >> > Any ideas now?
>> >> > Alex
>> >> >> Hi Alex,
>> >> >> helps:
>> >> >> Office
>> >> >> Update:
>> >> >> Options.
>> >> >> Go
>> >> >> microsoft
>> >> >> Best of Luck,
>> >> >> > stops
>> >> >> > it's
>> >> >> > stopped
