Excel SplitColumn and SplitRow(
O
OldDog
If I set up Excel like so:
$xl = New-Object -comobject excel.application
$xl.Visible = $true
$xl.DisplayAlerts = $False
$wb = $xl.Workbooks.Add()
$ws = $wb.Worksheets.Item(1)
and then do this: $xl.windows | gm
I see that there is a property called SplitRow and another called
SplitColumn.
SplitColumn Property int SplitColumn () {get} {set}
SplitRow Property int SplitRow () {get} {set}
So the question is how do I set these in my script?
And while we are at it, how about
Panes Property Panes Panes () {get}
I am told that this works in vbScript:
'Split Active Worksheet Window
With XL.ActiveWindow
.SplitColumn = 13
.SplitRow = 10
End With
TIA;
OldDog
M
Marco Shaw [MVP]
Like this:
$xl.activewindow.splitcolumn=2
$xl.activewindow.splitrow=2
$xl.activewindow.panes
Panes only has a "getter" method, so you can only read the property, while
the others have a getter and setter so you can actually modify the property.
I can't explain why you see those members with $xl.windows... I just
followed the VBScript code you provided.
Marco
"OldDog" <[email protected]> wrote in message
news:[email protected]
> Hi,
> $xl.Visible = $true
> SplitColumn.
> .SplitColumn = 13
> .SplitRow = 10
> End With
> TIA;
> OldDog
W
Wolfgang Kais
Hello old Dog.
"OldDog" wrote:
> Hi,
> $xl.Visible = $true
> SplitColumn.
> .SplitColumn = 13
> .SplitRow = 10
> End With
How about this:
$aw = $xl.ActiveWindow
$aw.SplitColumn = 5
$aw.SplitRow = 10
1..$aw.Panes.Count | % {
"The visible range of pane {0} has the address {1}." -f
$_, $aw.Panes.Item($_).VisibleRange.Address()
Regards,
Wolfgang
