Exception Code: c0000005
J
JoeP
Hi All,
It is Vista Ultimates 64 bits.
What can casue such an error. The whole computer got frozen up and had to
shut down the computer. Then I rebooted and clicked on the System short
cut and this time it got froject again. Well after that I turned off several
drivers via the MSConfig and ran a some chkdsk on the hard disks. For now it
is stable. I also have McAfee the coroporate version 8.5, and Spybot
installed on the computer. It worked fine for several weeks with the above.
Problem signature
Problem Event Name: APPCRASH
Application Name: vfp6.exe
Application Version: 6.0.8961.0
Application Timestamp: 399d513a
Fault Module Name: kernel32.dll
Fault Module Version: 6.0.6000.16386
Fault Module Timestamp: 4549be94
Exception Offset: 00023843
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1033
Additional Information 1: 8d13
Additional Information 2: cdca9b1d21d12b77d84f02df48e34311
Additional Information 3: 8d13
Additional Information 4: cdca9b1d21d12b77d84f02df48e34311
Extra information about the problem
Bucket ID: 418654411
Thanks,
Joe
R
Rick Rogers
Hi JoeP,
The error code (0xc0000005) usually is associate with a driver problem,
quite often sound. The file indicated, vfp6.exe, is associated with Visual
Studios. If you are using that, make sure it's a compatible version, don't
force an older one or try compatibility mode.
Was this a one shot ordeal, or has it ever repeated itself?
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"JoeP" <[email protected]> wrote in message
news:[email protected]
> Hi All,
> short cut and this time it got froject again. Well after that I turned off
> several drivers via the MSConfig and ran a some chkdsk on the hard disks.
> For now it is stable. I also have McAfee the coroporate version 8.5, and
> Spybot installed on the computer. It worked fine for several weeks with
> the above.
> Problem signature
> Locale ID: 1033
> Thanks,
> Joe
J
JoeP
Hi Rick,
With the VFP6.EXE it was a one shot ordeal. It happened twice but at that
time I just called the System dialog and from some reason it got frozen as I
explained at the beginning of this thread.
I disabled many drivers via MSConfig and also used your suggestion of
compatibility mode.
Thanks,
Joe
