Executing Stored Procedure from Powershell
A
ASCHNEIDER146
I saw an example of using System.Data.SqlClient.SqlCommand on at
http://mow001.blogspot.com/2005/12/getting-and-working-with-sql-server.html
I was wondering how I could use the SqlCommand Object to execute a
stored proc on a sql database and pass it paramters.
I found this C# example on how to execute Stored Procs
http://www.csharp-station.com/Tutorials/AdoDotNet/Lesson07.aspx
But I can't figure out how to translate the C# example into Powershell
Any help would be greatly appreciated
Thanks,
Andy
B
Brandon Shell
As a general rule:
Replace
Type foo = type(parameters)
With
$foo = system.type(parameter)
if your case:
c#
SqlConnection conn = new
SqlConnection("Server=(local);DataBase=Northwind;Integrated Security=SSPI");
SqlCommand cmd = new SqlCommand("Ten Most Expensive Products", conn);
rdr = cmd.ExecuteReader();
PowerShell:
$conn = new-Object
System.Data.SqlClient.SqlConnection("Server=nybba0sql;DataBase=Northwind;Integrated
Security=SSPI")
$cmd = new-Object System.Data.SqlClient.SqlCommand("Ten Most Expensive
Products", $conn)
$rdr = $cmd.EndExecuteReader()
I haven't tested these, but effectively that should do it. Simple put... you
have direct access to the .NET objects, but you have to fully qualify them.
Hoped this helped.
"ASCHNEIDER146" <[email protected]> wrote in message
news:[email protected]
> Thanks,
> Andy
A
ASCHNEIDER146
Thanks Brandon,
That definitely helps me get started.
However I am still stuck with figuring out how to add parameters. Just
to be clear, I am not a C# developer so all this dot net stuff is prety
new to me. I imagine I could do it with COM and ADO but I am trying to
learn to use .NET.
I am trying to figure out how to set the CommandType and then Add the
parameters. Here is the C# I found:
"CustOrderHist", conn);
// 2. set the command object so it knows
// to execute a stored procedure
cmd.CommandType = CommandType.StoredProcedure;
// 3. add parameter to command, which
// will be passed to the stored procedure
cmd.Parameters.Add(
new SqlParameter("@CustomerID", custId));
// execute the command
Thanks,
Andy
Brandon Shell wrote:
> As a general rule:
> Replace
> With
> if your case:
> c#
> PowerShell:
> $conn = new-Object
> Security=SSPI")
> Products", $conn)
> Hoped this helped.
> > Thanks,
> > Andy
B
Brandon Shell
Be careful that you only supply parameters to Stored Procedures that accept
it or you will get an error.
In this case I used CustOrdHist SP.
Code:
$conn = new-Object
Security=SSPI")
$conn.Open() | out-null
$cmd = new-Object System.Data.SqlClient.SqlCommand("CustOrderHist", $conn)
$cmd.CommandType = [System.Data.CommandType]'StoredProcedure'
# This Parameter Line This will error if Parameters are not accepted by
Stored Procedure.
$cmd.Parameters.Add("@CustomerID","ANATR") | out-Null
$rdr = $cmd.ExecuteReader()
While($rdr.Read()){
Write-Host "Product Name: " $rdr['ProductName']
$conn.Close()
$rdr.Close()
Brandon Shell
http://mybsinfo.blogspot.com/ Stop by some time :)
> Thanks Brandon,
> learn to use .NET.
> cmd.Parameters.Add(
> Thanks,
> Andy
>> As a general rule:
>> Replace
>> With
>> if your case:
>> c#
>> Security=SSPI");
>> PowerShell:
>> $conn = new-Object
>> Security=SSPI")
>> Products", $conn)
>> you
>> them.
>> Hoped this helped.
>> > Thanks,
>> > Andy
A
ASCHNEIDER146
Sweet.. that is exactly what I was looking for !!
-Andy
> Code:
> $conn = new-Object
> Security=SSPI")
> Stored Procedure.
> While($rdr.Read()){
> $conn.Close()
> $rdr.Close()
> Brandon Shell
> > Thanks Brandon,
> > learn to use .NET.
> > cmd.Parameters.Add(
> > Thanks,
> > Andy
> >> As a general rule:
> >> Replace
> >> With
> >> if your case:
> >> c#
> >> Security=SSPI");
> >> PowerShell:
> >> $conn = new-Object
> >> Security=SSPI")
> >> Products", $conn)
> >> you
> >> them.
> >> Hoped this helped.
> >> > Thanks,
> >> > Andy
