Expand a vhd
J
JackSpratt
No doubt this has been asked a thousand times.
Easy way to increase the size of a vhd?
I seem to have underestimated how quickly I would use up the size of my
win2.8k virtual.
Did a quick Google and found talk of 3rd party tools and stuff.
Does it take that?
S
Steve Jain
Yes. YOu can't expand a VHD beyond its maximum size without 3rd party tools
or imaging it to a larger VHD
> win2.8k virtual.
> Does it take that?
R
yes you can :-)
1. you do have an Hyper-V system available which can expand a VHD.
2. Have an Win7/R2 system available and use diskpart for expand the maximum
size of a VHD -> SELECT VDISK FILE="c:\test\test.vhd" -> EXPAND VDISK
MAXIMUM=100 (MB)
Regards
Ramazan
"Steve Jain" <essjae@newsgroup> wrote in message
news:DE9662DD-5ACC-400E-BCCA-53696CE60C08@newsgroup
> tools
>> win2.8k virtual.
>> Does it take that?
S
Steve Jain
One thing to keep in mind is the maximum limit for a VHD for VPC is 127GB.
Don't expand it beyond that.
> win2.8k virtual.
> Does it take that?
J
JackSpratt
RCan wrote:
> yes you can :-)
> maximum size of a VHD -> SELECT VDISK FILE="c:\test\test.vhd" -> EXPAND
> VDISK MAXIMUM=100 (MB)
Perfect... almost.
Now my guest OS has 28GB of unallocated space.
How do I merge this onto the existing drive?
> Regards
> Ramazan
>> tools
>>> win2.8k virtual.
>>> Does it take that?
B
Bill Grant
"JackSpratt" <pickledpork@newsgroup> wrote in message
news:OMDQPmw1KHA.5828@newsgroup
> RCan wrote:
>> yes you can :-)
> Perfect... almost.
Extend the partition.
J
JackSpratt
>> RCan wrote:
>>> yes you can :-)
>>> EXPAND VDISK MAXIMUM=100 (MB)
>> Perfect... almost.
using diskpart on the host? on the guest? disk management?
I tried right clicking on the (guest) C drive and extending but it won't
let me have the unallocated.
J
JackSpratt
#8
>>> RCan wrote:
>>>> yes you can :-)
>>> Perfect... almost.
ok got it
Run diskpart on guest os
select disk 0
disk detail
select volume 1
extend
done.
R
#9
Regards
Ramazan
news:uAjYn#Q2KHA.5820@newsgroup
>>>> RCan wrote:
>>>>> yes you can :-)
>>>> Perfect... almost.
> ok got it
> select disk 0
> disk detail
> select volume 1
> extend
> done.
