Expired Password
jnealmccoy
4
I tried to install an anti virus software yesterday and I am getting the message that my administrator password has expired, but it does not prompt me to input another password, it just keeps saying it is expired when I put in my current password. What do I need to do???
inc2000
74
change the settings top the Admin account from the CONTROL PANEL. LMK how it goes.
    Gateway ML6437-est. laptop
    Intel (R) Pentium(R) Dual CPU T230 @ 1.86GHZ /1.87 GHz
    factory installed/user customized
    3 GB
    onboard
    onboard
    onboard
    320gb wd caviar
    factory
    factory chassis
    factory
    touchpad factory
    factory
    AT&T DSL
    currently certified as the fastest computer in the city of 38761
inc2000
74
its various ways to change or the wost case scenerio would be to reinstall vista. i gonna go back through the posts and look at ur specs and try to make a fake account to work on it for ya.
    3 GB
    onboard
    onboard
    onboard
    320gb wd caviar
    factory
    factory chassis
    factory
    touchpad factory
    factory
    AT&T DSL
inc2000
74
ok -heres what i figured out. its about a dozen ways to solve the password issue because each computer company setup each type of computer up differntly.
as a first step...[computer is off]>[press power button] wait one second and start press the F8 key {"its on the top row of the keyboard"} kind of fast..example three time a second....a black screen should pop up with one of the options that says SAFE MODE. hit ENTER on that and Vista should load with a black screen and a box that says stuff about 'im in safe mode' yadyada...just hit OK or YES. wait about 30 seconds to a minute. Does the screen have safe mode in the corners? IF so then YEY..GO clik the Start button then go to Control Panel. And under User Accounts and Fam Safety clik ADDorRemove user accounts...Find and clik on the account that has the locked password and click REMOVE PASSWORD on the LEFT SIDE of the screen. then click REMOVE PASSWORD onthe next screen . and TADA!! just restart the regular way and that account has NO password. THIS IS JUST ONE OF MANY WAYS TO GET IN YOUR COMPUTER. any problem LMK
i hope that helps
    3 GB
    onboard
    onboard
    onboard
    320gb wd caviar
    factory
    factory chassis
    factory
    touchpad factory
    factory
    AT&T DSL
inc2000
74
oh i forgot when u do get to safe mode make sure to go in the ADMINISTRATOR account and not anyone else :)
    3 GB
    onboard
    onboard
    onboard
    320gb wd caviar
    factory
    factory chassis
    factory
    touchpad factory
    factory
    AT&T DSL
inc2000
74
#9
yey work!!!! LOL
    3 GB
    onboard
    onboard
    onboard
    320gb wd caviar
    factory
    factory chassis
    factory
    touchpad factory
    factory
    AT&T DSL
