Explorer doesn't start automatically
F
fmq
When i start my laptop, the Folder Explorer doesn't start when i start the
computer. Therefore i got completely blank empty background with no icons,
task bar or start menu. Only My Documents folder pops up.
I have to run the "explorer" manually from the Task Manager, and everything
starts up normally.
Any suggestions/solutions would be greatly appreciated.
R
Rick Rogers
Hi fmq,
Seems to be a common problem, but it's easy to fix. Follow these steps:
Click start, type 'regedit' and hit <enter> to open the registry editor.
Expand the keys at left to reach:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Click on this key, then locate the 'shell' string in the right pane. Double
click it, replace the contents with just:
explorer.exe
Click ok, then close the registry editor and reboot.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"fmq" <[email protected]> wrote in message
news:[email protected]
> everything
> starts up normally.
F
fmq
Rick
You are awesome. Finally back to normal.
Thanks
"Rick Rogers" wrote:
> Hi fmq,
> explorer.exe
> Best of Luck,
> > everything
> > starts up normally.
