explorer.exe wont load on startup
H
hoodster 2004
explorer.exe wont load on startup i have windows vista home premium. It just
opens up with my documents folder.
.Joe
1337 spammer
Try this fix:
1. click start> type regedit.
2. Navigate to the following HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogo n
3. The little key 8th one from the bottom should be "Shell"
4. Double click it and in the value date it should say Explorer.exe if it doesn't then type that in there.
5. Hit Ok and restarted your machine.
Let us know if that worked for you.
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main
    500 GB USB External
    160 GB USB External
    2TB USB External
    DSL 3MB
nanoboss
Hi
I had a Trojan Horse detected with my antivirus I tried to fix it using the recommendations from antivirus, it seems to work until ...
My system didint load exploere from startup, it hangs showing me my documents folder...
I hited ctrl+alt+del to show on the task manager than run Explorer.exe and the system starts and everything working fine, except that now i need to do that every time i start the computer.
performed a search and found this forum...
I have this line in this 8th key
Shell = Explorer.exe C:\WINDOWS\Config\lsass.exe
should I delete the "C:\WINDOWS\Config\lsass.exe" leaving the Explorer.exe alone?
R
ravenfaust
Same problem explorer wont load but loads a documents folder instead on
starup, i use the CTRL+ALT=DELT and use the run command to start Explorer.exe
"longsville" wrote:
> Yes you need to ete td on info, mine said exacthly the same, i deleted
> the extra tex to leave Explorer.exe then restart machine and it should
> work, any other probs add me on msn at [email protected] or email
> me at same addy
> Aleks
> longsville
fcasey0116
Thanks a lot this worked great. :D
What was in the shell file was:
explorer.exe C:\WINDOWS\Config\Csrss.exe
Any idea what the additional exe file may be?
Try this fix:
longsville
Im guessing that it is caused either byu a virus, or more likely an internet explorer add on that does not like a certain file....it happened to me a second time so im leaning towards an IE add on.....
let me know if there are anymore problems
K
Klexur
I am having the same problem but I have XP and it only loads the wallpaper
and mouse. I had this same problem before i reformatted my hard drive . How
can I fix this?
> > me at same addy
> > Aleks
> > longsville
O
OneOfThree
Thank you, Thank you, Thank you!! I had the same problem. Your fix worked. I
also had the same "explorer.exe C:\WINDOWS\Config\Csrss.exe " in my registry.
I can't tell you how relieved I am. Thanks ONE MORE TIME!
> longsville
ZeratuelX
Elite Gamer
Power User
Hey, I just found some info on this problem that looks like it hasn't been posted yet.
First off, here is a report on csrss.exe
csrss.exe is the main executable for the Microsoft Client/Server Runtime Server Subsystem. This process manages most graphical commands in Windows. This program is important for the stable and secure running of your computer and should not be terminated.
Also, you may want to try something like this:
Code:
Explorer.exe;C:\WINDOWS\Config\csrss.exe
    Dell XPS 420
    Dual Intel Core 2 Duo E6850 @ 3.0 GHz
    ACPI x86
    nVidia GeForce 8800 GT
    IDT High Definition Audio
    SyncMaster 2493HM Digital 24" Widescreen
    1920 x 1200
    Dual Western Digital 500GB Disk Drives
    Logitech G5 Gaming Mouse
    Logitech G11 Gaming Keyboard
    6k KB/s DL, 700 KB/s UP
