export-clixml and compare-object question
G
Gaurhoth
I'm trying to compare a "living" object with one imported using import-clixml, but compare-object is not seeing them as identical. See code:
PS ps:\> $g = gwmi -class win32_desktop
PS ps:\> export-clixml -path desktop.xml -input $g
PS ps:\> $h = import-clixml desktop.xml
PS ps:\>
PS ps:\> compare-object $g $h
InputObject SideIndicator
@{__GENUS=2; __CLASS=Win32_Desktop; __SUPERCLA... =>
\\COMPUTERONE\root\cimv2:Win32_Desktop.Name="N... <=
\\COMPUTERONE\root\cimv2:Win32_Desktop.Name="c... <=
\\COMPUTERONE\root\cimv2:Win32_Desktop.Name="S... <=
\\COMPUTERONE\root\cimv2:Win32_Desktop.Name=".... <=
My expectation was that Compare-Object would see the $g and $h as the same since $h is just the XML representation of $g written out with export-clixml and reimported with import-clixml. Am I missing something or my understanding of export/import-clixml totally off-base?
gaurhoth
O
/\\/\\o\\/\\/ [MVP]
I did meet Gaurhoth on IRC (#PowerShell on freenode)
and answered it there, but the workaround to get all properties ( -property
parameter does not support wildcards ) might be usefull for more people,
so I repost it here :
<mow002> as one is seralized they are different
<mow002> PoSH>$g | gm
<mow002> TypeName:
System.Management.ManagementObject#root\cimv2\Win32_Desktop
<mow002> PoSH>$h | gm
<mow002> TypeName:
Deserialized.System.Management.ManagementObject#root\cimv2\Win32_Desktop
<mow002> I found this trick to do a check on all properties (-property does
not support wildcards)
<mow002> compare-object $g $h -prop ($g |% {"$($_.psbase.properties | select
name)"})
Greetings /\/\o\/\/
"Gaurhoth" <gaurhoth@live.com> wrote in message
news:%23m9%23Z8FJHHA.3668@TK2MSFTNGP02.phx.gbl...
PS ps:\>
gaurhoth
