Export/Import-CliXml oddity
K
Keith Hill
I'm saving out the results of Get-Command like so:
gcm -type alias, filter, function, cmdlet | export-clixml > commands.xml
I then load that back in as:
$cmds = import-clixml commands.xml
However some things don't seem to work as I would expect e.g.:
> $cmds | ? {$_.CommandType -eq 'alias'}
which outputs nothing however the where expression works when you use it directly on GCM:
gcm -type alias, filter, function, cmdlet | ? {$_.CommandType -eq 'alias'}
CommandType Name Definition
Alias % ForEach-Object
I can get the deserialized version to work if I do this:
> $cmds | ? {[System.Management.Automation.CommandTypes]$_.CommandType -eq 'alias'}
Is this just an unfortunate consequence of round tripping?
Keith
R
RichS
Looking at the XML file produced I think its an issue with the way the its
constructed as much as anything
Richard Siddaway
Please note that all scripts are supplied "as is" and with no warranty
Blog: http://richardsiddaway.spaces.live.com/
PowerShell User Group: http://www.get-psuguk.org.uk
> directly on GCM:
> CommandType Name
> Definition
> Alias %
> ForEach-Object
> 'alias'}
> Keith
