external HDD format to FAT/FAT32
C
Craig008
i am having a problem with formating a couple of external HDDs to FAT for use
with PS3, vista will only allow me to format them to NTFS, is there another
way of formating them
grapes
K
Kerry Brown
Edit by dmex:
Vista can format using FAT/FAT32 and it works with any USB device of ANY size using DOS...
just type format /FS:FAT32 x:
replace x with the drive letter and Vista will format the device without any issues.
C
Craig008
cool thanks for that, i will just use many partitions, for different things i
think, 32gb is big enough for most and i will have more than one so it will
be OK. thanks for your help
grapes
K
Kerry Brown
Be aware that FAT32 also has a limit to the largest file size (4 GB). When
formatting external drives that need to be shared with devices that don't
work with NTFS I usually make one or two 32 GB FAT32 partitions then format
the rest of the drive as NTFS. This allows me to store files larger than 4
GB on the drive. This is useful for backups, video files, etc.
Kerry Brown
Microsoft MVP - Shell/User
D
Donald L McDaniel
Make your partitions SMALLER than 32GB, and you will be able to format them as
FAT/FAT32.
This is because Vista will NOT allow one to create a FAT32 partition LARGER than
32GB.
Sorry, friend.
Donald L. McDaniel
dmex
ɠɛɐǨ
2,632
Location
Fremantle, Western Australia
This is a old thread but all this wrong infomation must be cleared up....
Steven
Double
2
#8
How do you fat32 format a Notebook 160GB HDD in an external case? I tried the cmd method above and after it formatted for over an hour it said it was to large.
U
Uwe Sieber
#10
Confirmed. In fact it was read testing the sourface. Before
it comes to the real format action, it cancels.
For formatting drives >32GB with FAT32 an external
tool is required.
http://www.uwe-sieber.de/usbtrouble_e.html#format_fat32
Uwe
02abarks
1
#12
the best way for you to format to fat32 is to use a third party program
i have used EASEUS Partition Master 4.0 Home Edition and it does it in the blink of an eye
