External Optical Drive-Sata Connected
denret
I've connected a spare 2.5" sata optical drive in an enclosure to my Vista desktop via a sata cable direct to the motherboard. Power is from a 5v power connector on the
power supply.
Vista recognizes the drive, the device manager shows OK, however when I attempt to perform read or write functions from several different applications, I get errors after about 80% of the process is completed.
I've tried different disks, applications, etc. No success.
Am I missing something that needs to be set in Vista??????
Yard Dog
Hello and welcome, i was reading in a magazine , about how Sata cables are sometimes faulty. Do you have another cable to swap out with ?
Is Your SATA Cable Slowing Down Your Data Transfers? Max PC Investigates
Posted 11/15/2011 at 1:04pm | by Gordon Mah Ung
Read more here : Search | Maximum PC
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    Acer E181H ([email protected]) 128MB GeForce 6150SE nForce 430 (
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
townsbg
~~тσωηsвg~~
Also try another sata port or if possible your drive in another computer.
