Solved External usb floppy: change Drive letter from B to A
HawkeyeLOM
I have an external USB floppy drive that got assigned the drive letter B when it was plugged into one of the usb ports on the back of my PC.
I need to change it to letter A. The drive is not listed under computer management: disk management. Removing the drive and reinstalling does not chhange the drive letter. Removing the driver in device manager
results in installing new hardware, but with drive letter B. The Bios has several settings releated to usb devices--but nothing to do with drive letters.
so I am at a loss of how to fix this---any help would be most apreciated:D
lordbob75
Lord of Bobs
Vista Pro
Is there already a Drive A:?
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Lachesis
    Razer Tarantula
    not fast enough
Brink
Staff member
mvp
Hello HawkeyeLOM,
If you do not already have an A drive, then you might see if the drive is listed in DISKPART.
1. Open a elevated command prompt.
2. In the command prompt, type diskpart and press Enter.
3. In the command prompt, type list volume and press Enter.
NOTE: Look for the Volume # listed for the drive letter B. If not listed, then type exit and press Enter. You will not be able to change it with diskpart.
4. In the command prompt, type select volume # and press Enter.
NOTE: Substitute # with the actual volume # from step 3. For example, if the B drive was listed as Volume 1 in step 3, I would type select volume 1 and press Enter.
5. In the command prompt, type assign letter=A and press Enter.
NOTE: If you receive an error, then you will not be able to assign the letter A to the drive instead of B.
6. In the command prompt, type exit and press Enter.
7. Close the command prompt.
Hopefully you now have the B drive as the A drive now.
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
lordbob75
Lord of Bobs
Vista Pro
I see... Well try what Brink suggested for you, and get back to us with the results.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
lordbob75
Lord of Bobs
Vista Pro
I am assuming it is plugged in?
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Brink
Staff member
mvp
HawkeyeLOM,
Umm, ok.
In the BIOS CMOS settings, set the Floppy Drive A to None or Disabled to see if it may free up the letter A for the USB floppy drive to use instead.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
HawkeyeLOM
No such settings in BIOS Intel motherboard DP45SG Bios 108
Only thing I have not tried is removing both the floppy usb control and usb floppy drive in device manager
HawkeyeLOM
FIXED: I uninstalled the NEC USB floppy controller under Universal serial Bus controller in Device Manager. Unpluged the drive, waited a few seconds and pluged back in---Device manager installed new controller and floppy. This time it shows as Drive A in Computer.
Thanks for all the help and suggestion--it helped me to get to this point
Brink
Staff member
mvp
You're welcome HawkeyeLOM. I'm happy to hear that you got it sorted out. :)
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
lordbob75
Lord of Bobs
Vista Pro
Good job!
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
