Externals Have Slowed down to a standstill startup
Fiery
Sorry if this is the in the wrong area
Gday
Today Chrome when I was closing a page down,BSOD my desktop, when it restarted my Wallpaper (pictures) which I keep backed upon one of my externals didn't come up.
I checked the path first, then I opened Computer,and not 1 of my 3 External Drives was showing, as I sat there thinking WTF, 1 External came back, the other 2 were a no show.
I checked the power to them was on, not to sure but 1 may have not been in the socket properly. So I took the USB out, plugged it back in, and it eventually showed in Computer. (This is the one with my wallpaper). Set my Wallpaper.
They're all WD Externals.
Rebooted, when the machine restarted the Wallpaper was MIA again, opened Computer, and after about 45 seconds the External showed up.
I then uninstalled all the drivers to the External, rebooted, added them back one by one, the drivers installed successfully. I reset my Wallpaper, rebooted again.
Be damned when the machine restarted NO WALLPAPER AGAIN!!
Anyone have any ideas as to why this has just started happening, and any clues as to how to fix?I forgot to add I have run sfc/scannow no errors and also chkdsk no errors
And last I used Macrium to do a restore of an image, prior to this all beginning, When It booted up my Wallpaper was there, then when I restarted the machine *poof* back to square one.
    Homebuilt
    AMD Phenom II x 4 965
    Gigabyte GA-MA770T-UD3P
    4GB DDR3
    Nvidia GeForce GTX 750 TI
    Creative Sound Blaster X-Fi Xtreme Audio
    Phillips 19"
    1280 x 1024
    1 x 128GB Samsung 840 Pro SSD
    1 x 1TB Sata
    1 x 160GB IDE
    1 x 2Tb WD External My Book Elite
    1 x 1TB WD External My Book Elite
    1 x 4TB WD External My Book
    Thermaltake 850W XT
    Coolermaster Storm Sniper Black Edition
    AC-ALPINE-64PRO ARTIC COOLING
    Microflacid Sterile
    12 year old Compaq, cant see any of the letters anymore :)
    ADSL2+
    My husband and I divorced over religious differences.. He thought he was God and I didn't.
Fiery
Anyone please?? I have a couple of programmes that I run from the Externals. This problem is causing the desktop icons to be modified. I have a 128GB SSD that I don't want being filled up by things that don't have to be run from the C:\
I reinstalled the OS just last month, made a Macrium Image, I rolled it back to that clean install, when it booted up my Wallpaper was back. Then when I rebooted *poof* gone again.
I have of course tried swapping the USB ports, it hasn't made a difference :/
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    1 x 1TB Sata
    1 x 160GB IDE
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
ilikefree
Plug all your drives in then
Press Windows Key and E
Then right click on Computer in Windows Explorer and click Manage
Click disc management in storage
see if all your drives show up with letters next to them
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Fiery
Done already they do
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    1 x 1TB Sata
    1 x 160GB IDE
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
ilikefree
Go to Device Manager
Click on and Expand [ Universal Serial Bus Controllers ]
Right click each entry and select Properties.
Left click Properties.
Select Power Management Tab.
ENSURE NO CHECK MARK IN BOX [allow the computer to turn off this device to safe power].
Post back after checking.
    LENOVO 64734VM
    15 inch
    External Speakers
ilikefree
Also try
Go to Start search and type
Services
Once the services program loads find Background intelligent transfer service and stop it
Right click it and go to properties and set the start up to manual
and also try this
Open Control Panel
Switch to Classic View
Select Program Features
Choose Turn Windows features on and off
Scroll down and uncheck Remote Differential Compression
    LENOVO 64734VM
    15 inch
    External Speakers
Fiery
Also try
Services
and also try this
Open Control Panel
Okay done that, rebooted, very slow to reboot, BUT my externals were read. Probably due to the slowness of the startup
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    1 x 1TB Sata
    1 x 160GB IDE
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
