Extract data out of a seemingly complex structure
C
Curious
I define a variable ("result") as object. Its value is set by
following code:
object result = splusObject.GetType().InvokeMember("ReturnValue",
System.Reflection.BindingFlags.GetProperty, null, splusObject, null);
Then both bad news and good news. Bad is that "result" seems to be a
matrix. In my debugger, it is:
Dimensions:[1..2, 1..2]}
[1, 1] 112
Good news is that it contains the correct value I want, "112".
I've tried to extract "112" out of result, but to no avail.
Any advice on how to extract "112" out of this complex structure of
result? Thanks!
S
Stanimir Stoyanov
Judging from the debugger output, 'result' is a jagged array. If you are
sure that the result is always a jagged array the following code will let
you extract the value at [1, 1]. Make sure there are enough elements in the
matrix though, in order to avoid receiving a IndexOutOfRangeException.
int[,] b = (int[,])result;
int resultValue = b[1, 1];
Stanimir Stoyanov
http://stoyanoff.info
"Curious" <fir5tsight@xxxxxx> wrote in message
news:3494ebbd-ceb9-4887-a0f5-bcc221d0c5bd@xxxxxx
> following code:
> [1, 1] 112
> result? Thanks!
